Calculating Velocity of Sphere on Inclined Plane
  • Thread starter Thread starter moondawg
    Velocity
The discussion focuses on calculating the velocity of a sphere as it rolls up a 25-degree incline. The sphere has an initial translational speed of 10 m/s and a mass of 25 kg, with a moment of inertia defined as I=2mr²/5. The user calculated the total kinetic energy, including translational and rotational components, and added potential energy (mgh), resulting in a total of 3015 J. However, confusion arose regarding the final velocity, as the calculated speed of 15.53 m/s seemed incorrect since the sphere should not speed up while ascending the incline. Clarification was sought on the inclusion of potential energy in the calculations.
moondawg
A large sphere rolls wothout slipping across a horizontal surface. The sphere has a constant translational speed of 10m/s,mass of 25 kg, radius of .2m. The moment of inertia of the sphere about its center of mass is I=2mr2/5. The sphere approaches a 25 degree incline of height 3m as shown above and rolls up the incline without slipping. Calculate the spheres velocity just as it leaves the top of the incline.
I found total kinetic energy by adding translational kin enery, rotational kin energy and (mgh)... i got 3015J and then set that number equal to the equation for kin energy (1/2mv2) and found my new v and got 15.53 m/s but that can't be correct bc if its initial vel as it was going toward the ramp was 10 m/s then why would it speed up if its going up a ramp? idk what i did wrong pleaseee help.!
Why did you add mgh? Explain exactly what you did.
  • · Replies 19 ·
