Calculating Voltmeter's Resistance
  • Thread starter Thread starter ZxcvbnM2000
    Resistance
The discussion focuses on calculating the resistance of a voltmeter connected to a 5 V battery, which reads 4.9 V when connected. The internal resistance of the battery is determined to be 0.5 Ω based on the current delivered to a 12 Ω load resistance, which is 0.4 A. The voltage drop of 0.1 V across the internal resistance indicates that the voltmeter's resistance must be calculated considering its configuration with the battery's internal resistance, which is in series, not parallel.
  • Understanding of Ohm's Law (V = IR)
  • Familiarity with series and parallel circuit configurations
  • Knowledge of internal resistance in batteries
  • Ability to solve basic circuit equations
  • Calculate the voltmeter's resistance using the formula Rv = (Vterminal - Vbattery) / I
  • Explore the implications of internal resistance on circuit performance
  • Study the differences between series and parallel circuits in more detail
  • Learn about the impact of load resistance on voltage readings in circuits
This discussion is beneficial for electrical engineering students, physics enthusiasts, and anyone involved in circuit analysis or instrumentation, particularly those working with voltmeters and battery systems.
ZxcvbnM2000
A battery is known to have an emf of 5 V, but when a particular voltmeter is
connected to it the reading is 4.9 V. With the voltmeter disconnected and a load
resistance of 12 Ω connected to the battery, a current of 0.4 A is delivered. What
is the resistance of the voltmeter?
Okay first of all i found that the internal resistance of the battery is 0.5 Ω .
since I = E/(R+r) .
But to find the meter's resistance is a bit confusing ...
Since their is a voltage drop of 0.1 V it means that the voltage drop across r and the voltage drop across Rv(voltmeter's resistance) should be equal to 0.1 V right ?
So Vr + Vx =0.1 ?
I have no idea ?! :S
since I = E/(R+r) .
So Vr + Vx =0.1 ?
In the voltmeter measurement, what is that 0.1V dropping across... And what important info does knowing that give you...?
I think you can assume that the voltage that the voltmeter displays is the voltage across its own resistance.
Thank you for your answers.
So we can say that Vterminal = E - Ir ?
so 4.9 = 5 - Ir <=> 0.1 =Ir so the voltage drop across the battery's internal resistance is 0.1 V so this either means that the voltmeter has zero resistance or they are in parallel.Right ?
But if they are in parallel then all 5 volts should be available right ??!
Argh !
Sure.
No, it means that the current is such that 0.1V is dropped across the internal resistance. It doesn't determine the voltmeter's resistance. If the leads of the voltmeter are connected across the battery terminals, then the voltmeter resistance must be in series with the internal resistance of the battery.
https://www.physicsforums.com/attachment.php?attachmentid=47633&stc=1&d=1337910519
Argh !
They are not in parallel.
You have two circuits to consider. One has the voltmeter resistance as a load and the the other has 12 Ω as a load. You're given two resulting "measurements". Both situations have some common components. You should be able to write equations for each situation, each with one unknown value, and solve for the unknowns.
  • · Replies 25 ·
