Calculating Volume Under Implicit Surface: Cartesian Coordinates
  • Thread starter Thread starter crox
    Surface Volume
10 replies · 3K views
crox
calculating volume under a surface, defined by implicit function f(x, y, z)=0 (in cartesian coordinates, strictly not in polar). Because the function that i need to integrate is quite complicated and there would be no obvious way to double check the result i first tried to calculate volume under sphere, but i get the wrong result.
so let it be [tex]f(x, y, z)=x^2+y^2+z^2-1[/tex]
[tex]V=8*\int dxdydz[/tex]
where dz is integrated from 0 to [tex]\sqrt{1-x^2-y^2}[/tex], dy from 0 to 1 and the same with dx. The multiplication factor 8 is added to get the whole volume.
I use Mathematica for solving the equation and get [tex]\frac{2}{3}(2\pi - i*(-4 + \log{16}))[/tex]
what am I doing wrong?
This should work for you.
[tex]8 \int_{x = 0}^1 \int_{y = 0}^{\sqrt{1 - x^2}} \int_{z = 0}^{\sqrt{1 - x^2 - y^2}} dz~dy~dx[/tex]
The first (inner) integration calculates the volume of a stack of small cubes, from the x-y plane up to the surface. The middle integration makes a wall of those stacks, going from y = 0 to the circle in the x-y plane. The final (outer) integration integrates those walls to give the volume of 1/8 of the sphere.
Wouldn't it be easier, since you're integrating a sphere, to use spherical coordinates?
Thanks, Mark.
@Char. Limit
Yes, it would be easier in this case, but not in general (sphere served only as an example)
I'd have one more question regarding this sphere example - how could I rigorously calculate the surface area?
If I got the formula correctly, this could be done with:
http://en.wikipedia.org/wiki/Area - general formula (bottom of the page)
again in the case of sphere: [tex]f(x, y)=R^{2}-x^{2}-y^{2}[/tex]
and the boarders are determined by [tex]x^{2}+y^{2}=R^{2}[/tex]
but I still don't get the predicted result - [tex]4\pi R^2[/tex]
I could really use some help again:)
The graph of this function is not a sphere - it's a paraboloid. For a sphere of radius R, centered at (0, 0, 0), the equation is x2 + y2 + z2 = R2.
If you solve for z, you get
[tex]z = \pm \sqrt{R^2 - x^2 - y^2}[/tex]
If you define f(x, y) to be the positive square root of the above, you get a function whose graph is the upper hemisphere.
I think you mean borders:wink:
back again (thanks Mark44 for fas reply), but I still have questions.
Let's say that I have a surface defined by [tex]x^2+y^2=f(z)[/tex] or rewritten [tex]x=\pm\sqrt{f(z)-y^2}=f(z, y)[/tex].
The formula for surface area is in this case: [tex]P=\int\int\sqrt{ (\frac{\partial f(y, z)}{\partial y})^2+(\frac{\partial f(y, z)}{\partial z})^2 +1 } dy dz[/tex],
where we first integrate [tex]dy[/tex] from [tex]y=\pm\sqrt{f(z)}[/tex].
The borders (:)) for [tex]dz[/tex] are then defined by the zeros of function [tex]f(z)[/tex].
is this OK?
I'm not sure what you mean above. The expression on the left is a function of x and y, but the one on the right is a function of z alone.
In your integral below you have f(y, z), so is f a function of one variable or two?
is this OK?
Sorry, when I read it again I saw that it is unclear:
f(z) is any function, that depends on z - for example: [tex]x^2+y^2=(z-1)^2[/tex] - this is some given function.
In the case of f(y, z) I just wanted to stress the dependence and f(y, z) serves only as an abbreviation.
Instead of complicating things by having f(z) on one side and a different function of x and y on the other, can you just solve for z to get z in terms of x and y?
In your example, x2 + y2 = (z - 1)2, so
[tex]z - 1 = \pm \sqrt{x^2 + y^2}[/tex]
[tex]\Rightarrow z = 1 \pm \sqrt{x^2 + y^2}[/tex]
Here z is NOT a function, but the upper half of the graph is a function (of x and y), and the lower half is a function as well.
The upper half of the graph uses the positive square root; the lower half uses the negative square root.
Looking at your example and previous posts about the iterated integral some more, you could have x as a function of y and z. Using your example, x = (z - 1)2 - y2. Solving for x gives
[tex]x = \pm \sqrt{(z - 1)^2 - y^2}[/tex]
Here, x is in terms of y and z, but is not a function. If we restrict x to be nonnegative, then we get a function:
[tex]x = + \sqrt{(z - 1)^2 - y^2} = f(y, z)[/tex]
For x <= 0, we get another function
[tex]x = - \sqrt{(z - 1)^2 - y^2} = -f(y, z)[/tex]
