- 10,069
I'm glad we agree.OldYat47 said:Yes, #3 is the best shift option.
I like that. You are so tenacious! Let's see what happens when we redo the same thought experiment as I did in my previous post, but by changing the 2nd gear ratio to a higher gear instead of a lower gear. Let's call it gear 2d:OldYat47 said:You could also set the 2nd gear ratio such that maximum torque occurred at 35 KPH. That case would give the best acceleration from 35 KPH to 36 KPH after a 3rd to 2nd downshift.
Can we agree that by setting a higher gear ratio, the whole traction force curve will go down and cover a greater speed range?
Can we agree that Fmax in gear 2d will be smaller and at a faster car speed than in 2nd gear?
Let's go to an even higher gear ratio. Let's call it gear 2e:
Look at that, Fmax is now precisely at 35 km/h! And it is a lot less than the traction force in 2nd gear. Note also that if I just set it to a slightly higher gear ratio, I will be in 3rd gear.
Now you should also be able to appreciate that Fmax in 2nd gear is not the greatest force you can achieve at 25 km/h; F@pmax in 1st gear is much greater at that same speed.
No matter what gear ratio you're in when at Fmax, there is a lower gear ratio that will create a greater force at the same speed with F@pmax.
If you want to move a point from left to right, it will also have to move down. That is because engine power is always the same, which is equal to the wheel power, and wheel power is F X v, so if v increases and power is the same, then F must go down.
Can we agree that Fmax will never offer the greatest possible acceleration at a given speed?
Can we agree that the maximum acceleration at any given speed depends on the engine maximum power?
You may now appreciate more my answer to one of your previous posts:
And I answered (I added comments in red to relate to examples from my previous post):OldYat47 said:For example, suppose you have an engine that generates 250 units torque at 7,000 RPM and 233.3 units of torque at 7,500 RPM. The power in both cases is the same (1.75X10^6 units of power). Suppose maximum power occurs at 7,250 RPM. Then it's easy to generate a power curve that would be maximum at that point and yields 242.8 units of torque (1.76X10^6 units of power).
jack action said:But the car doesn't go at the same speed at 7000, 7250 or 7500 rpm.
Let's say I want the wheel to turn at 1000 rpm. The gear ratio needed for having the engine at 7000 rpm will be 7:1. For 7250 rpm, you will need a 7.25:1 gear ratio and a 7.5:1 for 7500 rpm. What are the wheel torque then, knowing the wheel rpm is the same in all cases?
250 * 7 = 1750 units torque [--> corresponds to gear 2a]
242.8 * 7.25 = 1760 unit torque [--> corresponds to gear 2b]
233.3 * 7.5 = 1750 units torque [--> corresponds to gear 2c]
Note how the wheel torque is the same when at 7000 or 7500 rpm; That is because the power is the same in both cases. Yet, the wheel torque is greater at 7250 rpm; That is because the power is greater. And the wheel torque increase is directly proportional to the power increase (1.76X10^6 / 1.75X10^6 = 1760 / 1750).
