Calculation of leptonic decay widths
  • Thread starter Thread starter luis_m
    Calculation Decay
5 replies · 2K views · last reply
luis_m
Halzen & Martin, problem 2.25
The ρ and ω wavefunctions are u[itex]\overline{u}[/itex]-d[itex]\overline{d}[/itex] and u[itex]\overline{u}[/itex]+d[itex]\overline{d}[/itex] except for a normalization factor.
In this problem one has to evaluate the expectation value of the charge operator for each of the mesons listed using their quarks wavefunctions and then square them but I get the same value of that expectation value for both ρ and ω so their squares will never be in the ratio 9:1.
Any ideas of what I'm doing wrong?
Thanks!
You have to add the individual contributions and square the sum, not the other way round. This should give a ratio of 3:1 for the sum (as 2/3+1/3 != 2/3-1/3) and 9:1 for its square.
Thank you for your reply, mfb.
I appreciate the point that one has to square afterwards.
I think that my problem lies in the evaluation of the expectation value of the charge operator for each meson. What I'm doing for the ρ meson, for instance, is
[itex]\langle u \overline{u}-d \overline{d}|e_1+e_2|u \overline{u}-d \overline{d} \rangle=\frac{2}{3}-\frac{1}{3}-\frac{2}{3}+\frac{1}{3}=0[/itex],
where [itex]e_1[/itex] and [itex]e_2[/itex] represent the charge operators for each of the quark/antiquarks.
Obviously conceptually there is something wrong but I'm not sure what.
Thank you for your attention.
u can go to d + positive lepton only, u-bar can go to d-bar + negative lepton only - they are two different processes and do not add.
I do not quite understand your reply.
So, what I'm doing for calculating the expectation value of [itex]e_1[/itex], for the sake of the argument, is
[itex]\langle u\overline{u}-d\overline{d} | e_1|u\overline{u}-d\overline{d}\rangle=\langle u\overline{u}|e_1|u\overline{u}\rangle + \langle d\overline{d}|e_1|d\overline{d}\rangle = \frac{2}{3}-\frac{1}{3}=\frac{1}{3}[/itex]
and analogously for [itex]e_2[/itex].
Calculate the decay widths for positive and negative leptons separately - they are two different processes, the amplitudes do not add.
