Calculation of neutral Kaon Box Diagrams
The forum discussion focuses on the calculation of the amplitude for neutral Kaon oscillation using Box diagrams. The participants discuss the Dirac structure of the diagrams, the GIM mechanism, and the importance of gamma matrix algebra. Key points include the necessity of careful handling of mass terms and the realization that the two Box diagrams do not cancel out due to differing quark connections, requiring a Fierz rearrangement to account for an additional minus sign in the total amplitude.
  • Understanding of Feynman diagrams and their representation in particle physics.
  • Familiarity with the GIM mechanism in the context of flavor physics.
  • Proficiency in gamma matrix algebra and Dirac notation.
  • Knowledge of Feynman parametrization and Wick rotation techniques.
  • Study the GIM mechanism in detail to understand its implications in particle interactions.
  • Learn about Fierz rearrangement and its application in quantum field theory calculations.
  • Explore Feynman parametrization techniques for integrals in quantum field theory.
  • Investigate the derivation of S_0(x_t) from A(x_i, x_j) in the context of large top quark mass.
Particle physicists, theoretical physicists, and graduate students studying quantum field theory and flavor physics will benefit from this discussion.
johnpatitucci
Hi everybody,i'm worried about some calculation. I have to write down the amplitude for the neutral Kaon oscillation. There are two Box diagrams which are depicted here:
http://upload.wikimedia.org/wikipedia/de/9/92/FeynmanKaon.png
The two diagrams come along with a combinatorical factor of 1/2 and they have a relative sign according to the possible contractions.
Now I get for diagram on the left with W-exchange in (\xi =1) gauge up to some constants the following dirac structure (external momenta neglected)
[\bar(s) \gamma_{\mu} (\slashed{k} + m_1) \gamma_{\nu} d] \otimes
[\bar(s) \gamma_{\nu} (\slashed{k} + m_2) \gamma_{\mu} d]
Now, wenn calculating the right diagram, i get basically the same, which together with the relative sign would give a vanishing full amplitude.
Does anybody know, what i am doing wrong ?
Just to fix TeX:
[\bar{(s)} \gamma_{\mu} (\not k + m_1) \gamma_{\nu} d] \otimes<br /> [\bar{(s)} \gamma_{\nu} (\not k + m_2) \gamma_{\mu} d]
without looking closely, there IS going to be a partial cancellation. This is called the GIM mechanism. But the cancellation will not be complete. You have to be very careful with gamma matrix algebra, etc. That "basically" should translate to: "almost, but NOT QUITE!"
BTW: there are other diagrams that matter, including the ones with a "c" and a "t" on the internal lines. You're going to need those.
Well, thanks for your replies. But just think of my expression with masses replaced according to
m_1 -> m_i , m_2 -> m_j and sum over i,j = u,c,t. I've done that. The masses vanish by moving the helicity projectors to the right and therefore you can write the sum behind this expression, so that it only acts on the masses in the denominator [= (k^2 - m_i^2)(k^2-m_j^2)* (k^2 - M_W^2)].
There has to be something else.
(Sorry, how do i implement TeX here ?)
"[ t e x ]" to open and "[ / t e x ]" to close
The masses do NOT vanish! The final answer should be of the form:
G_F^2(m_1^2 - m_2^2)
That's the GIM mechanism. So the term that is independent of masses DOES vanish, but the term with the masses only vanishes in the particles have the same mass. Check your gamma matrix algebra again! That's probably where you went wrong.
Also, if you want to include tex within the paragraph (like g_{\mu\nu}), use "[ i t e x ]" and "[ \ i t e x ]" (without the spaces between the letters, obviously).
Hi,
I started to calculate the neutral Kaon Box Diagram, can anyone tell me what is the first step to solve this integarl
I = \int \frac{d^4 k^2}{(k^2-M^2_W)^2 (k^2 - m^2_i) (k^2 - m^2_j)}
which appears in the dominator.
I think we need first to make feynman parametrization then wick rotation. Is it right ?
Because I can't do the right parametrization.
thx
Hi
I realize that this thread is very old, but it's new to me! Anyway, it seems to me that there are more questions here than answers (and some answers seemed to be misleading). So please allow me to first summarize the calculation in order to clarify the question, and then make a suggestion for the answer.
The Question:
Basically the question is how do the two box diagrams, which are equal and sum with a relative minus sign, not sum to zero? (The sum should actually give a function A(x_i,x_j) rather than zero.)
The calculation:
I've attached the relevant Feynman diagrams for the W boson box diagram which I'm going to discuss (see bottom of post). The reason I include it is because the original post linked to some diagrams which had a few mistakes.
Starting from the diagram on the left, and using the Feynman Gauge, it's easy to find,
<br /> \left(\frac{g}{\sqrt{2}}\right)^4<br /> \sum_{i,j=u,c,t}\lambda_i \lambda_j \int \frac{d^4 q}{(4\pi)^4}<br /> \,(\bar{d}\gamma^\mu P_L \frac{i(\not\! q+m_i)}{q^2-m_i^2}\gamma^\nu P_L s)\,<br /> (\bar{d}\gamma_\nu P_L \frac{i(\not\! q+m_j)}{q^2-m_j^2}\gamma_\mu P_L s)<br /> \left(\frac{-i}{q^2-M_W^2}\right)^2<br />
As the projection operators must match (i.e. P_L P_R =0), and recalling that P_L changes to P_R whenever it passes a \gamma^\mu, it is clear that the m_i and m_j terms are zero, leaving only the \not\! q terms;
<br /> \frac{g^4}{4}<br /> \sum_{i,j=u,c,t}\lambda_i \lambda_j \int \frac{d^4 q}{(4\pi)^4}<br /> \,\frac{q_\alpha q_\beta}{D}<br /> \,(\bar{d}\gamma^\mu \gamma^\alpha\gamma^\nu P_L s)<br /> (\bar{d}\gamma_\nu \gamma^\beta\gamma_\mu P_L s)<br />
Here we have defined, \lambda_i=V^{}_{is}V^{*}_{id}, where V is the CKM matrix, and
<br /> \frac{1}{D}=<br /> \frac{1}{(q^2-M_W^2)^2}\frac{1}{q^2-m_i^2}\frac{1}{q^2-m_j^2}<br /> \,.<br />
The next step is to do the integration using,
<br /> I_{\alpha\beta}(i,j)\equiv \int d^4 q \, <br /> \frac{q_\alpha q_\beta}{(q^2-M_W^2)^2(q^2-m_i^2)(q^2-m_j^2)}<br /> = \frac{-i\pi^2}{4 M_W^2}A(x_i,\,x_j)\,g_{\alpha\beta}<br />
with x_i=m_i^2/M_W^2. The function A is defined by,
<br /> A(x_i,\,x_j) = \frac{J(x_i)-J(x_j)}{x_i-x_j} <br />
and
<br /> J(x_i)=\frac{1}{1-x_i}<br /> + \frac{x_i^2 \,\ln x_i}{(1-x_i)^2}<br />
This is actually easy to prove, but I'll leave it out for now. Using this we now get
<br /> \frac{-i\,g^4\,\pi^2}{16 M_W^2(2\pi)^4}<br /> \sum_{i,j=u,c,t}\lambda_i \lambda_j <br /> \,A(x_i,\,x_j)<br /> \,(\bar{d}\gamma^\mu \gamma^\alpha\gamma^\nu P_L s)<br /> \,(\bar{d}\gamma_\nu \gamma_\alpha\gamma_\mu P_L s)<br /> \,.<br />
Next we simplify the combination, (\bar{d}\gamma^\mu \gamma^\alpha\gamma^\nu P_L s)<br /> \,(\bar{d}\gamma_\nu \gamma_\alpha\gamma_\mu P_L s). All you need to do here is make use of the \gamma matrix
identity,
<br /> \gamma^\mu \gamma^\alpha \gamma^\nu<br /> = g^{\mu\alpha}\gamma^\nu + g^{\nu\alpha}\gamma^\mu <br /> - g^{\mu\nu}\gamma^\alpha - i\epsilon^{\mu\alpha\nu\beta}\gamma_5 \gamma_\beta<br />
to show that,
<br /> (\bar{d}\gamma^\mu \gamma^\alpha\gamma^\nu P_L s)<br /> \,(\bar{d}\gamma_\nu \gamma_\alpha\gamma_\mu P_L s)<br /> =<br /> 4\,<br /> (\bar{d}\gamma^\mu P_L s)<br /> \,(\bar{d}\gamma_\mu P_L s)<br />
and then the result for the left diagram becomes,
<br /> -\frac{i\,g^4\,\pi^2}{4 M_W^2\,(2\pi)^4}<br /> \sum_{i,j=u,c,t}\lambda_i \lambda_j <br /> \,A(x_i,\,x_j)<br /> \,<br /> (\bar{d}\gamma^\mu P_L s)<br /> \,(\bar{d}\gamma_\mu P_L s)<br /> \,.<br />
Now if we do the same calculation for the box diagram on the right we actually get the same result. So how is it that we don't get zero when we add up the two diagrams?
My suggested answer:
The 4-quark operators which appear in the two diagrams aren't actually the same.
They connect different s-quarks to different d-quarks. In the left diagram it is the two initial(final) state quarks which are connected, while in the right diagram it is one from the initial state and one from the final state. In order to become the same 4-quark operator we need to use a Fierz rearrangement,
<br /> (\bar{d}_{1L} \gamma^\mu s_{2L})<br /> \,(\bar{d}_{3L} \gamma_\mu s_{4L})<br /> = -<br /> (\bar{d}_{1L} \gamma^\mu s_{4L})<br /> \,(\bar{d}_{3L} \gamma_\mu s_{2L})<br />
and hence introduce an extra minus sign, so that the total is just twice that for the first diagram given above.
Does anyone know if this is the correct solution to the problem?
Does anybody can give me a hint on how to reach
<br /> S_0(x_t) = \frac{3}{2}\frac{x_t^3}{(1-x_t)^3} \ln{x_t} - [\frac{1}{4}+\frac{9}{4}\frac{1}{1-x_t}-\frac{3}{2}\frac{1}{(1-x_t)^2}] x_t<br />
from
<br /> A(x_i,\,x_j) = \frac{J(x_i)-J(x_j)}{x_i-x_j}<br />
in the limit of large mt?
Please open a new thread, this one is from 2010.
