Calculus based physics differences algebra based physics
32 replies · 140K views · last reply
Basically with calculus we are able to expand upon the ideas presented with an algebraic approach to physics. Not only can the algebraic equations be derived using calculus but there are some cases where it is much more practical (and easier) to use calculus.
For instance say we wanted to find a velocity of a function at a certain time, with only knowing it's position at any given time. Without calculus the best we can do is approximate this. But since a velocity is just a change in position, if we find the change in position over an infinitely small time interval we can find the actual velocity of an object. This would be an example of differentiation.
An example of integral calculus would be something like this. Say you have a rigid rod and you wanted to calculate the force of gravity the rod exerts on another object at sometime. Well to do this we need to chop the rod up into finitely small parts and find the force for all of these parts, then sum them together to get the total force. Without calculus goodluck summing up the force of an infinite number of pieces of a rod.
Also you can have differential equations (Just shows how a particular function is changing) and you might want to calculate a value of the function at a particular point. A good example of this would be a spring that is dampened.
algebra based physics is what pre med students take
calc based physics is what science/engineering majors take.
simple as that.
awvvu said:
That makes absolutely no sense. And the units don't match up either.
Oh the plus should be a x and the m should be a v. I just did some basic antidifferentiation.
