Calculus Finals Review: Seeking Tutoring/Help
The discussion centers on a user seeking help for their upcoming Calculus finals, specifically requesting assistance with problems from a review sheet. Key topics include finding derivatives, applying the product and quotient rules, and solving continuity issues in piecewise functions. Participants provide hints and corrections, emphasizing the importance of careful application of formulas and checking work for errors. The user expresses confidence in achieving a good grade despite initial confusion, indicating a proactive approach to mastering the material. Overall, the thread highlights collaborative learning and problem-solving in preparation for a final exam.
hodeez
Ok, so I have my Calculus Finals this coming Thursday, and I hope I receive some "tutoring" or review. The teacher sent out a review sheet via email, and I mirrored it www.hodeez.com/max3_finals.doc[/URL]
Just need a little/some help on 1,4,6,7,10 and the long problem.
Of course I know the rules and I'll show you my work first, but as of right now, I'm at work and my cable @ home keep disconnecting me. So I'll brief what I can get by today hopefully :)
For Prob 4
f(x)= |2x+3|-|x-4|
draw the no line
Code:
x                  -3/2          0           4
f(x)= -(2x+3)-{-(x-4)} | 2x+3 -{-(x-4)}      | 2x+3 -(x-4)
Code:
for   x<-3/2 u have   |2x+3|=-(2x+3)  & |x-4|= -(x-4)
-3/2<=x<4             |2x+3|= (2x+3)  & |x-4|= -(x-4)
      x>=4            |2x+3|= (2x+3)  & |x-4|=  (x-4)
now i believe u can recombine the above in specified interval to get f(x)
For problem 1 \frac{df(x)}{dx}= 0 \text{ as the tangent is horizontal say at point x=t}
u will get Quadratic Equation find the roots to 3 decimal place
For the problem 6 find -dx/dy which will be the slope of the normal
For problem 7
Apply the formula \frac{d (\frac{u}{v})}{dx}=\frac{ v\frac{du}{dx}-u\frac{dv}{dx}}{v^2}
here u and v are u=cosx and v= sqrt(2x-3)
For problem 7
from what I am understanding, (6) you want me to find the reciprocal negative of the derivative of the original equation? OR find the implicit differentiation and then plugging in the (2,1)
(7) = seems like the division rule, how did i ever miss that? [zz)]
thanks for the replies, I am going to look more indepth into the answers you gave me. :smile:
Giving Hints for long problem
lim(x->3)f(x)=f(3)
i.e f(3-h)=f(3+h) for h->0 and h>0
and f&#039;(x)=\lim_{h \rightarrow 0}\frac{f(x+h)-f(x)}{h}
u can substitute x= 4 here and so on
DOH! another simple one over looked
I must say all are simple
u can do it either way
lim(x->3)f(x)=f(3)
im quite consfused on the way you are approaching it. I am thinking, if its continuous the 1st piece must match the 2nd piece @ 3 and then i set it up for k/3+2=k-3-1 and then solved for k which = -9 , then the slope must equal so I am finding the deriv of both pieces and then trying to make them equal again.
May you check this (#9):
y'' = -3(sin^2(x))*(cos^2(x))
and then plug in pi/6 = 180/6 = 30, yes?
For long problem 2
Take the first hiker along x-axis and other at an angle of 35 deg
After time t its(1 hiker)coordinate will be(2.25t,0) and for second hiker it would be (3.8cos35 t,3.8sin35 t}.
Now apply the distance formula and and differentiate it to get ur answer substitute for t=5.4/2.25
Also it could have been done easily be relative velocity concept but i feel that u have to give Calculus exam right
may i know how u reach at y'' = -3(sin^2(x))*(cos^2(x))
it is incorrect Pls show me ur steps
though pi/6=30 is correct
y'= 3(sin(x))(cos(x))
y''= 3 * product rule (sin(x))(cos(x))
= 3 * (sin(x))*(-sin(x))+(cos(x))(cos(x))
look
y=sin^3x \Rightarrow y&#039;=3sin^2x (cosx)
u got y' wrong in ur reply
For long problem 2
is the answer 56.52 rounded?
I used the Cosine Formula for triangles.
Also, I am interested in hearing your relative velocity concept. =)
look
wow, that would have caused havok on the final
Again how u reached the answer for hiker prob it is incorrect
The method, I'm sure is correct, because that is the method we were taught to use. But my mechanics are probably incorrect. I'm using the Google calculator as I don't have my graphing calculator right now.
Yup i know the method using the cosine formula is correct u need to recheck ur steps u might be making small errors in calulating
cos35 = \frac{(2.25t)^2+(3.8t)^2-x^2}{2*2.25*3.8 t^2}
After little rearrangement
x^2=5.495000043t^2
so u will get x=2.344141643t
x^2=5.495000043t^2
My formula is C= A^2+B^2-cos(c)*A*B
Is that the correct form?
But 2.344 seems too way out of proportional
u have again quoted the wrong formula the formula which i have quoted previously is authentic
I see my error, I forgot to square the C and derive it, so then I would have to divide the right side by C... Gotta run to the store for my co-workers, so I'll be right back to figure that out :smile:
hope i got this
OH NO! the 2!
ugh, i think i understand the concept, so let's recede back to the short answers! :wink:
OH NO! the 2!
As far it goes I analyze you , Ur concepts seems to be Ok But your calmness and correctiveness to do a problem is absent u are just making mistakes in formula or small mistakes which are turning out otherwise.
I Advice u to remember the formula(s)with proper definition and Pls do and apply the formula with extreme care.I believe a lot of practice with these problems will help u to get good grade/marks
Before leaving i give u another advice
The besy way to improve with these kind of a non conceptual errors
is to note down the errors which u have make and then try not to repeat those error
No worries, I usually achieve 90+ marks and the first one to leave the classroom/finish the test. I hate checking =_=
Can't seem to solve Long problems #1.
All I got was a) which is K=9(?) to make it continuous. But to use the H method for B got me all confused!
  • #31
f&#039;(4)=\lim_{h\rightarrow 0}\frac{f(4+h)-f(4)}{h}
f&#039;(4)=\lim_{h\rightarrow 0}\frac{\frac{9}{4+h}-\frac{9}{4}}{h}
f&#039;(4)=\lim_{h\rightarrow 0}-\frac{9h}{4h(4+h)}
so f'(4)=-9/16
  • #32
thanks himanshu, but i seem to have got it in school, before i got a chance to see your answer. Even so, the problem was logically incorrect ( f'(4) was suppose to be f'(3)). I should be 85+ for my finals. thanks.
