Calculus problem involving finding coordinates
10 replies · 3K views · last reply
5ymmetrica1
Using calculus, find the coordinates of the point on the line y =-2x+5, which is closest to the origin, and the corresponding value of D
y = -2x +5
I know I need to find a line that is perpendicular to the line of the equation, but I'm not sure how to find the equation of this line so that I can make the equations equal to each other.
Something like
d(x) = x2+y2
= x2 + (-2x+5)2
= x2 + 4x2+25
= 5x2 + 25
am I on the right track?
Assuming that [tex](-2x + 5)^{2} = 4x^{2} + 25[/tex] is terrible.
I'm not good at calculus but this problem is quite easy, even though a mistake like this one can ruin your answer.
Be careful that
[tex](-2x + 5)^{2} = (-2x + 5)(-2x + 5) =\ ...[/tex]
To add to besulzbach's reply, note that what you are calculating is the distance squared from the origin to a point on the line. (Not that there's anything wrong with that.) :smile:
If the line y1 = -2x + 5 has a slope of -2, then a line perpendicular will have a slope of 1/2.
Since you are trying to find the points closest to the origin, the equation of the perpendicular line is y2 = (1/2)x
This should be enough...
...although whether it qualifies as a method "using calculus" is uncertain.
True... he mentioned wanting to find a line perpendicular, so I went with that.
Ah that's embarrassing! I forgot to expand the problem, I been away from math for to long haha. thanks for the replies guys!
So
is it 4x2 - 10x -10x + 25
= 4x2-20x+25
if f(x)= 4x2-20x+25
then f'(x) = 8x -20
and f''(x) = 8
if 8x - 20 = 0
8x= 20
x= 20/8
x=2.5
y = -2x + 5
y = -2(2.5) + 5
y = 0
So coordinates are (2.5, 0)
How does this look
Using Calculus:
f(x) = x2 + y2, where y = -2x + 5
so, f(x) = 5x2 - 20x + 25;
therefore, f'(x) = 10x - 20.
If f'(x) = 0 when f(x) is minimum, then
0 = 10x - 20, so x = 2.
Then, y = y(x) = y(2) = -2(2) + 5 = 1.
The coordinate is (2, 1).NOTE: This agrees with the other "non-Calculus" method I used earlier.
So
= 4x2-20x+25
if f(x)= 4x2-20x+25
You left out an ##x^2## from the other term.
[tex]f(x) = 5x^{2} - 20x + 25[/tex]
Is NOT the function for the distance, it is the formula to find the square of the distance!
(...) and the corresponding value of D
Use that [itex]f(x)[/itex] to make a function [itex]d(x)[/itex] that gives you the distance for any input value of [itex]x[/itex].
[tex]d(x) = \sqrt{5x^{2} - 20x + 25}[/tex]
Any point [itex](x, (-2x + 5))[/itex] will be [itex]\sqrt{5x^{2} - 20x + 25}[/itex] from the origin. Now you can calculate D as you wanted.
thanks for your help guys
So the next question asks me to make a conjecture and prove it with algebra
So I know that I need to do the same thing as with the first part but using
y = ax + b
f(x)=x2+y2
f(x)=x2+(ax+b)(ax+b)
f(x)=x2+a2 x2+2axb+b2
then do I differentiate this?
I'm not sure how to make a conjecture based on this though
