Calculus with the electric field
The discussion focuses on calculating the electric field at point P due to a line segment of length L. Participants emphasize the importance of setting up appropriate coordinate axes, specifically placing the line along the x-axis with the left end at the origin. The solution involves considering the contribution to the electric field from a small line element dx, characterized by a charge density denoted as lambda, and integrating these contributions. Utilizing trigonometric functions, particularly sine, is crucial for relating the small section of the conductor to the distance from the observation point.
  • Understanding of electric fields and charge density
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of trigonometric functions, particularly sine
  • Ability to set up coordinate systems in physics problems
  • Study the principles of electric fields and their calculations
  • Learn integration techniques in calculus, focusing on applications in physics
  • Explore the use of trigonometric functions in physics problems
  • Review coordinate system setups for various physics scenarios
Students studying physics, particularly those focusing on electromagnetism, as well as educators and tutors assisting with calculus-based physics problems.
pakman2012
1. Find the electric field at point P for a line segment with length L. Diagram attached.
attached equations
I have next to no clue on how to do this question. My first idea was to try and set up one of the lengths as r, and work from there, but I wasn't able to do anything conclusively. The most confusing part is not being able to do the calculus and relating the variables to fit the purposes of the problem. How exactly do you find the potential of something like this, in general?
Any help for this question will be greatly appreciated.
First pick appropriate coordinate axes. The line along the x-axis and the left end at the origin for example.
Then consider the contribution to E resulting from a small line element dx (with charge density lambda say) and add up (integrate) all the contributions.
The trick is to use sine to relate the small section of conductor(dx) to the distance from your point.
  • · Replies 19 ·
  • · Replies 22 ·
