Came up with a problem that I can't solve
The discussion revolves around a physics problem involving a hoop of mass M and radius R with a point mass m placed on top, exploring where m will leave the hoop as it rolls without slipping. Participants share their equations based on conservation of energy, escape conditions, and relative motion, noting the complexity of the problem and the challenge of solving it using high school physics principles. Some contributors argue that the problem is too advanced for high school students, while others believe it can be tackled with basic mechanics. The final consensus suggests that the angle at which the mass m leaves the hoop can be derived from a specific equation involving both masses and gravitational forces. Overall, the problem highlights the intricacies of dynamics and the application of classical mechanics in a non-trivial scenario.
guv
Imagine a hoop with mass M and radius R that will only roll without slipping on the floor. Place a point object with mass m on top of the hoop and then the system starts from at rest. Question: where does m leave M?
If one fixes the hoop or let the hoop slide, solutions can be found using high school mechanics. I ended up with 3 complicated equations with 4 unknowns. Can the given problem be solved using high school physics?
Thanks
Science news on Phys.org
Why not post what you've come up with? I'm trying to wrap my head around this problem.
The 3 equations I have are based on the following principles:
1. Conservation of energy (static friction between hoop and floor does no mechanical work):
mgh = 1/2 m v_{bg}^2 + 1/2 M v_{hg}^2 + 1/2 I \omega ^2
h = R(1-cos(\theta))
\theta is the angle where the point mass m (ball) leaves the hoop.
Note, one cannot use conservation of momentum in either horizontal and vertical direction and since the static friction and normal force acting on the hoop is not linearly related, there is not necessarily any simple relationship between horizontal and vertical impulse that allows the use of state function variables...
2. Escape condition Normal force = 0:
mg sin(\theta) = m \frac{v_{bh}^2}{R}
3. Relative motion ball relative to ground v_{bg}, hoop relative to ground v_{hg}, and finally ball relative to hoop form a triangle which allows the use of law of cosine.
\vec v_{bh} = \vec v_{bg} - \vec v_{hg}
Looking at the set of equations, one has the following unknowns:
\theta (where the ball leaves the hoop), 3 speeds v_{bg}, v_{bh}, and v_{gh}
This system has two degrees of freedom: ##\psi## is the angle of hoop's rotation and the angle ##\phi## which determines the place of point m till it does not slide out from the hoop. I expect that the Lagrangian of this system ##L## does not depend on ##\psi## and thus in addition to the law of total energy conservation you have the law of conservation of generalaized impuls ##p=\frac{\partial L}{\partial \dot\psi}## If you could obtain this by means of the high-school methods it would be useful to solve the problem :smile:
Thanks a lot, very beautiful problem. We (me and students) solved it today on our classes
Likes ProfuselyQuarky
wrobel, do you mind posting the solution you used in your class? Thanks!
huh, found the 4th equation through the horizontal change of momentum, and the angular impulse-momentum relationship:
##\int f_s R dt = \Delta L = I \omega ##
##\int f_s dt = \Delta p = m v_{bg,x} - M v_{hg} ##
wrobel, thanks! I work with high school students interested in physics olympiad. I don't have the luxury to teach them lagrangians and hamiltonians. I do use the ideas and principles but I can't really use the detailed calculations.
what type of students are you working with? Do you think high school students should know lagrangians to have a shot in national/international physics olympiad?
I gave this problem to students which study the baccalaureate degree program in mathematics. I believe that this problem is suitable for theoretical mechanics course in university not in high school. I think this problem is too complicated for high school it is too complicated even for olympiad in high school
I have found a misprint in the pdf file above. It is written ##\boldsymbol{OA}=(x+R\sin\phi)\boldsymbol e_x+R\cos\phi\boldsymbol e_y.##
Must be ##\boldsymbol{OA}=(x+R\sin\phi)\boldsymbol e_x+(R+R\cos\phi)\boldsymbol e_y.##
Fortunately this does not change other formulas.
If the hoop doesn't have linear velocity, the angle will be the same as m falling from an inclined plane, related only to μs, coeff of static friction between m and M. If the hoop gets a velocity, the result is a quadratic equation in Cos or Sin of the angle. Quite solvable.
The answer is as follows. The angle of leaving ##\phi\in(0,\pi/2)## is found from the equation
$$3\cos\phi-\frac{m}{m+2M}(\cos\phi)^3=2.$$
The detailed proof here
Simply use your mind and imagine an answer first. There are variables to the answer. the weight of m compared to the weight of M makes a difference in the speed of the increase of speed of rotation and thus the point of separation. That is why Cub Scout derby cars must be limited to the weight and it is very important to be as close to the maximum as possible. The heavier the rolling object is the faster it accelerates also depending on it's density of mass.
A gold marble will roll faster down a 10 degree slope than a glass marble of the same diameter.
Also consider, if mass m is placed exactly on the top of the arc of hoop M, it will not start rolling. Then you have to factor in the initiating force of push off.
Not if it has the same coefficient of friction. Both force from gravity and inertia are proportional to mass, the mass cancels in the equations.
Take the limit for the push going to zero.
Friction. Surrounding atmosphere and surface rolled on. Go get your marbles and give them a try. A steel one against a glass one and perhaps a plastic one will give you a close enough answer.
I did the problem numerically.
Assuming:
M = 1 kilogram
R = 50 centimeters
m = 10 grams
g = 9.806 m sec⁻²
Edited. I did the problem wrong. I assumed that the hoop was spinning about an axis and that its center of mass did not gather any translational momentum. I'll try again.
Beautiful! ok. Just use your mind and bring your version of the solution to initial problem with formulas and detailed comments. Everyone can shoot the breeze
A hoop of mass M and radius R, initially at rest, has very, very near its top a point mass, m.
The point mass will fly off the hoop when the magnitude of the centrifugal acceleration (positive) equals that of the sum of the forces pushing the point mass toward the hoop's center (negative).
The centrifugal acceleration = ω²R
The radial component of acceleration of gravity = −g cos θ
The radial component of the hoop's translational acceleration = −RΩ sin θ
ω²R − g cos θ − RΩ sin θ = 0
where
ω is the angular speed of the hoop
g is the acceleration of gravity
Ω is the angular acceleration of the hoop
θ is the angle by which the hoop has turned since the initial time
The moment of inertia for a hoop of mass M and radius R about its axis of symmetry,
I = MR²
The angular acceleration, Ω, is equal to the torque, τ, divided by the moment of inertia.
Ω = τ/I
The torque is the component of the gravitational force on the mass m that is perpendicular to the vector from the hoop's center to the mass m, multiplied by the moment arm length, R.
τ = mgR sin θ
So the angular acceleration, as a function of θ, is
Ω = (m/M) (g/R) sin θ
We are looking for the θ and ω that satisfy
ω²R/g − [cos θ + (m/M) sin²θ] = 0
Let's consolidate the constants.
k = (m/M) (g/R)
Ω = k sin θ
Assume a small, but non-zero, initial angular displacement, θ₀ > 0.
Assume an initial angular speed of zero, ω₀ = 0.
Assume a very small time step, Δt.
Ω₀ = k sin θ₀
ω₁ = ω₀ + Ω₀ Δt
θ₁ = θ₀ + ½ (ω₀+ω₁) Δt
Ω₁ = k sin θ₁
ω₂ = ω₁ + Ω₁ Δt
θ₂ = θ₁ + ½ (ω₁+ω₂) Δt
Ω₂ = k sin θ₂
ω₃ = ω₂ + Ω₂ Δt
θ₃ = θ₂ + ½ (ω₂+ω₃) Δt
And so on, until
ωᵢ²R/g − [cos θᵢ + (m/M) sin²θᵢ] = 0
@Jenab2
I also got a very similar equation, a quadratic equation, but my equation
included not only g, R, and V (ω) but also μs, coeff of static friction between m and M.
Is μs embedded in one of your constants?
There are two critical statements of the problem:
1) The particle m can slide on hoop without any friction
2) The particle m can not slip till it falls from the hoop
I solved the problem in the first statement. The second statement is much easier than the first one, it is of high school level indeed.
So you consider the problem in the second statement. Your assertion is wrong. You did not take into account that the center of hoop moves. In the statement #2 the particle m describes a cycloid, not the circle.
I solved the problem in the first statement. The second statement is much easier than the first one, it is of high school level indeed.So you consider the problem in the second statement. Your assertion is wrong. You did not take into account that the center of hoop moves. In the statement #2 the particle m describes a cycloid, not the circle.
One of the forces pushing the point mass toward the center of the hoop arises from the fact that the center of the hoop moves. I did take that force into account, and not merely the force from the component of gravity in the direction of the center of the hoop.
O, I see
Ω = τ/I
τ = mgR sin θ
I have another question. What about the torque produced by the force of friction between the floor and the hoop?
There is no answer to a problem with infinity of variables. The variables must all be stated and known. This problem states some of them but not all.
However after sleeping on this problem and giving it a lot of thought, my opinion is that the object m, regardless of all variables, will depart contact when the radian of M at m reachers gravitational level.
mfb said:
Not if it has the same coefficient of friction. Both force from gravity and inertia are proportional to mass, the mass cancels in the equations.Take the limit for the push going to zero.
I did not reply or add the "Then you have to factor in the initiating force of push off." Do not know how that got there, copied from an above answer. The friction would not be the same as the weight of gold increases friction in contact with sloping surface. Gravitational pull on heavier gold will overcome atmospheric friction on the same size diameters surface areas. Both must be calculated for each material to calculate speed of each for length traveled. Push off force could be entered if used and would need to be the same for each which would cause the heavier gold to start off slower or could use the same push off speed, thus requiring calculating difference of push off force.
He did not ask for the angle of leaving. He asked for the point of leaving. Either way, I am betting your answer is wrong.
where
I = MR²
Ω = τ/I
τ = mgR sin θ
k = (m/M) (g/R)
Ω = k sin θ
Ω₀ = k sin θ₀
ω₁ = ω₀ + Ω₀ Δt
Ω₁ = k sin θ₁
ω₂ = ω₁ + Ω₁ Δt
Ω₂ = k sin θ₂
ω₃ = ω₂ + Ω₂ Δt
And so on, until
Very good answer but you left two components out. One being the friction of the hoop M on the surface it is rolling on that I assume you consider also zero and the other being the friction holding the "point object m" to the outer surface of M which is important.
Consider for comparison if the point object m is round instead and thus rolls as well. This becomes a slightly different equation but works very similar.
I still believe the answer to both situations is at gravitational level radian, regardless of weight of each M and m.
The angle is equivalent to that position, see the picture in post 3.
Huh? Point mass m moving toward center of hoop? Impossible. It is on a surface strong enough to keep it on the circumference of the hoop until it falls away from the hoop outer surface. The hoop is in motion toward the direction point mass m is effectively pulling it by pushing with gravity force downward.
  • #31
Post #3 does not have a picture. Thus, angle to what? Horizontal radian at point of release? Or verticle radian? An angle of 2 what then? 2 degrees above or below horizontal or what?
  • #32
Alright I made a mistake, post 4.
But have you read the entire thread?
As to finding a solution, perhaps going purely mathematical could work (understanding it).
First try to find the EOM for ##\phi## and ##\psi## (at first sight they look equivalent) using the Lagrangian formalism.
Next suppose you have an initial condition with angle ##\phi=\delta \phi## where ##\delta\phi## is infinitesimal.
Then one could check using an iterative method what the solution could be (and if it's feasible).
  • #33
A little confused because you are now communicating under a different name. Does not matter, Assume associate. My education is old and not a complete college degree. But, I do know and used extensive math on several different professions. Know nothing of Lagrangian and never learned the complete greek alphabet nor used it much. I use what I know from experience combined with education and experimentation.
Regardless of the comparative density and mass weights and comparative sizes of m and M, without "push off" force, I cannot believe the speed will increase enough for centrifugal force to enter the equation in a calculable amount. Thus my answer in an earlier post of point of leave being at gravitational level radiant. If m is too heavy, M will slip. If M is too heavy or large in diameter it will not continue from even a push off.
Any way you look at the problem with only presented stats, it is not solvable mathematically nor with just establishing an equation.
  • #34
I wasn't arguing against your explanation, it's how I would explain it as well.
The proposition was how I would approach the problem if I was trying to find an explicit solution :-)
I might follow through on the approach if I find the time (not before the end of June)
Odd that you see my name changing, I've had it since way back in 2011.
  • #35
I guess you replied to a reply of mine to another poster and I did not recognize that since the system does not show who the replies are to.
  • #36
Friction is also proportional to mass. If we neglect air resistance, all forces and energies are proportional to mass, and acceleration is independent of it. A simple dimensional analysis shows the same.
  • #37
mfb, I see my comment was not clear for some reason. The gold friction on the sloping surface would be more than that of glass that is more than plastic. The increased friction I was referring to would be the air resistance that is too large to ignore. I do not mean increased. Not sure why I used that word. The marbles I was mentioning must be the same diameter so mass would be the same and thus air friction the same. Gravitational pull is the major force.
