navneet1990
- 78
- 0
can 1 = 2 ??
is this possible
1 = 2
is this possible
1 = 2
Nope.navneet1990 said:hence,
root -1 / root 1 = root 1 / root -1
hence,
i / 1 = 1 / i
A rational number is, by definition, a number of the form [tex]\frac{p}{q}[/tex], where [tex]p \in Z[/tex] and [tex]q \in N[/tex]. So, you can't write -5/4 as 5/-4.navneet1990 said:...[ -5/4 can also be written as 5/-4...cant it? i mean -1/1 is the same as 1/-1 right??]...
Eeeh, wherever do you have this limitation from??radou said:A rational number is, by definition, a number of the form [tex]\frac{p}{q}[/tex], where [tex]p \in Z[/tex] and [tex]q \in N[/tex]. So, you can't write -5/4 as 5/-4.
jnorman said:i remember my father showing me a proof once that 1=2, but can't quite recall it. but, if you start with the equation:
x^2 -1 = 0, you can factor x^2 - 1 into (x+1)(x-1)=0
then divide both sides by x-1, and get x+1=0.
for a value of x=1, you have shown that 2=0.
That is NOT the definition of a rational numberradou said:A rational number is, by definition, a number of the form [tex]\frac{p}{q}[/tex], where [tex]p \in Z[/tex] and [tex]q \in N[/tex]. So, you can't write -5/4 as 5/-4.
..Or let's state it this way: there is no need for q to be an integer. It is enough for q to be a natural number.radou said:It's a standard definition.
radou said:Btw, does it appear logical to divide with a negative number
radou said:as well as take Wolfram definitions sooo seriously![]()
So, you didn't have any arguments after all.radou said:It's a standard definition. Btw, does it appear logical to divide with a negative number as well as take Wolfram definitions sooo seriously..Or let's state it this way: there is no need for q to be an integer. It is enough for q to be a natural number.
radou said:Right, but let's put it this way. Let's define the set of rational numbers as [tex]Q=\left\{\frac{p}{q}:p \in Z , q \in N\right\}[/tex]. If we compare two different rational numbers, then we have [tex]p_{1}>p_{2} \Rightarrow \frac{p_{1}}{q}>\frac{p_{2}}{q}[/tex]. Now, let's define the set of rational numbers as [tex]Q=\left\{\frac{p}{q}:p, q \in Z , q \neq 0 \right\}[/tex]. Then we have [tex]p_{1}>p_{2} \Rightarrow \frac{p_{1}}{q}>\frac{p_{2}}{q}[/tex] if [tex]q > 0[/tex] and [tex]p_{1}>p_{2} \Rightarrow \frac{p_{1}}{q}<\frac{p_{2}}{q}[/tex] if [tex]q < 0[/tex]. So, in the first case, it's easier to compare two rational numbers, which may make the first definition more convenient. Sorry if I'm tiresome, () but it's the defiition that I found in almost all my math textbooks (mathematical analysis, elementary math, etc.), so I'm convinced there's a reason for it.
That is just flat wrong and neither of the definitions you cite say that. A rational number is not a number written in that form- it is a number that is equal to something in that form!radou said:A rational number is, by definition, a number of the form , where and . So, you can't write -5/4 as 5/-4.
Hubert said:So what is the fault in the "proof"? I assume it has something to do with the fact that both i and 1/i (or -i) are solutions to the equation x^2 -1 = 0, just as both 2 and -2 are solutions to the equation x^2 + 4 = 0.
