Can 4 Pin Tactile-Micro be Used as On-Off Switch?
  • Thread starter Thread starter Kussy
    Pin
The discussion revolves around the use of a 4 pin Tactile-Micro switch as an on-off switch. Participants explore the functionality and potential applications of this type of switch in various circuits.
  • Exploratory, Technical explanation, Debate/contested
  • One participant questions whether a 4 pin Tactile-Micro switch can function as an on-off switch, suggesting that they are typically push-to-make and release-to-break.
  • Another participant confirms the switch type and notes that it breaks the circuit and goes off.
  • A participant proposes that there are methods to use this style of switch to switch a circuit on and off, referencing its common use in various electronic devices.
  • Concerns are raised about potential switch bounce, which may cause double triggering in circuits, and a modification is suggested to mitigate this issue.
Participants express differing views on the functionality of the switch as an on-off mechanism, with some suggesting it can be adapted for such use while others emphasize its typical operation as a momentary switch. The discussion remains unresolved regarding the best approach to utilize the switch in this manner.
Participants note the potential for switch bounce and its implications for circuit behavior, indicating that further experimentation may be necessary to fully understand the switch's performance in specific applications.
Kussy
Can we used the 4 pin Tactile-Micro as a on-off switch?
hi Kussy
would you like to clarify a bit ... a 4 pin Tactile-Micro what ?
I assume you mean switch ? like one of these ...
I'm not aware of any that stay on ... ie they are all push make - release break
Dave
Yes that one in the picture
It's just break the circuit and go off
OK there are ways to use this style of switch to be able to switch a circuit on and off
here's one example ...
this process is common in so much gear these days ... TV's VCR's DVD players etc etc
you will understand that that portion of the circuit will always have power on it
cheers
Dave
Thank you davenn that's very useful
no probs
if you do build this to experiment, you may find it suffers a little from switch bounce
that is a pulse produced when contacts make and another when they break. This will cause
double triggering in the flipflop IC
there is a small mod that can be done to stop that
Dave
  • · Replies 27 ·
  • · Replies 31 ·
11K
