Can a Chi2 test be used on uniform p test results?
The discussion centers on the appropriateness of using a Chi-squared test versus a Kolmogorov-Smirnov (KS) test for analyzing a series of p-values expected to be uniformly distributed. It is noted that the KS test is preferred for small sample sizes, as it evaluates the maximum difference between the empirical and theoretical cumulative distributions without losing information through binning, which is required for the Chi-squared test. The assumption that uniformly distributed p-values should cluster around 0.5 is identified as flawed; instead, they should be randomly spread across the range of 0 to 1. The conversation highlights the importance of understanding the underlying distribution when selecting the appropriate statistical test. Ultimately, the KS test is deemed more suitable for this scenario due to its flexibility and power with small datasets.
Paul Uszak
Not sure that I've phrased the question correctly. If you have a series of p values from a series of tests, and they're all meant to be uniformly distributed, why do you have to do a KS test on that, and not another Chi-squared test?
The following is an extract from a test program's output:-
Test no. 1 p-value .886973
Test no. 2 p-value .473563
Test no. 3 p-value .358962
Test no. 4 p-value .894858
Test no. 5 p-value .767457
Test no. 6 p-value .583446
Test no. 7 p-value .227626
Test no. 8 p-value .765091
Test no. 9 p-value .298747
Test no. 10 p-value .108371
Results of the OSUM test for pu256.bin
KSTEST on the above 10 p-values: .059581
The p-values are meant to be uniformly distributed across 0.0 to 1.0. This implies that they should all be 0.5ish. Why doesn't the program (Diehard randomness tester) perform a Chi-squared test on the ps? This happens several times in the complete report, so I take it to be deliberate. It's always a KS test on uniformly distributed ps. Isn't the Chi-squared test numerically simpler too?
This is a contradiction. If the values of p are uniformly distributed, they should not be clustered around 0.5.
Here is my 2 cents. For Chi-squared, you have to divide the sample data into bins. That loses a lot of information and you do not have a lot of data (10 values of p). Since KS looks at the maximum difference between the cumulative distribution of the sample versus the theoretical cumulative distribution, it is more powerful for small data sets.
Likes Paul Uszak
Hmm, sound like I'm confusing discrete and continuous distributions... Again. I'd made the assumption that if the p-values were uniformly distributed 0 - 1, then the expected p-values would be 0.5, hence a Chi-squared test could be attempted. As I write my assumption, I can see that it's logically flawed.
Chi-Test tests that variables fit a chi-distribution which is the sum of the squares of independent standard normal variables. The K-s test makes no assumptions of an underlying distribution so for uniform variables it is a better choice.
You are right that the expected value of p, uniform in [0,1], would be 0.5. But that does not mean that the values will cluster around 0.5. In fact they should be randomly spread between 0 and 1. As an extreme example, suppose you can have a random variable X which is 0 half the time and 1 the other half. Then its expected value is 0.5, but it is always at 0 or 1.
PS: There can be more clustering in uniform random than you would expect, but there is no reason for the clustering to prefer 0.5.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
