Can a direction cosine squared be negative?
17 replies · 4K views · last reply
Krushnaraj Pandya
A line makes some angle T with each of x and z axis, and angle U with y-axis so that sin^2(U)=3sin^2(T).
2cos^2(T)+cos^2(U)=1 ...(i)
cos^2(x)+sin^2(x)=1
Using the above two eqns. give us the correct value for cos^2(T) which is 3/5 as per my textbook but plugging it back into (i) gives us cos^2(U)= -1/5. Am I wrong somewhere or is it a mistake in the book?
cos^2(x)+sin^2(x)=1
How are you getting ##\cos^2 T = \frac35##? Clearly that is too large, given your first equation.
cos^2(x)+sin^2(x)=1
Of course for ##\ \cos(U) \ ## having a real number value, its square cannot be negative. Something's wrong.
The maximum value of sin2 U is 1, when U = 90°. Then T is ±45° and sin2 T =1/2, so your initial equation must be wrong.
sin^2(U)=3sin^2(T). is given- change it to cos^2 and it gives us this
Must've been a mistake in the book, thank you very much
Alright, Thank you for your help :D
Does the book give a result for ##\ \cos(U) \,,\text{or } \cos^2(U) \,?##
Where did the ##3/5## come from?
Changing the given equation in sin to cos we get 3cos^2(T)-cos^2(U)=2. Using 2Cos^2(T)+Cos^2(U)=1 we have 2 equations in two variables, adding both gives cos^2(T)=3/5
The book says cos^2(T)=3/5. which gives a negative value of cos^2(U)
Where does this equation come from?
There seems to be another anomaly, which is perhaps connected- there is a mcq saying- "A line OP through origin is inclined at 30 and 45 degrees respectively to OX and OY. The angle at which it is inclined to OZ is given by?" And the correct option given is "Not any angle" even though using the same equation ∑cos^2(θ)=1 gives us 3/4 + 1/2 +cos^2(x)=1 which again gives a negative value of cos^2(x)
Okay, I understand now. You can see that the two cones implied by those angles do not intersect, so no such line exists.
Is that the case for the original question as well? Or perhaps they just forgot this relation and only wanted to test if I knew sum of direction cosines is 1? Because the observation that one of it is negative is a secondary one derived after getting the answer in the first place and wasn't noticed by the question-setter
Your guess is as good as mine.
Thank you very much, I am quite sure now that that is the case
