Can a homemade electromagnet with aluminum strips withstand 120 volts?
  • Thread starter Thread starter Mindstormed
    Electromagnet
Constructing a homemade electromagnet using aluminum strips and a 120-volt household current poses significant safety risks, especially for those inexperienced with AC mains power. The circuit must be designed to allow current flow, typically requiring a closed switch, but caution is advised due to potential hazards like short circuits and overheating. Aluminum strips are not ideal for electromagnets due to difficulties in soldering and unstable resistance, which can lead to dangerous conditions. It is recommended to experiment with low-voltage, low-power electromagnets instead, as they are safer and more manageable. Overall, thorough knowledge of electrical safety standards and regulations is crucial before attempting such projects.
Mindstormed
I'm not too knowledgeable on electricity, but I'm constructing an electromagnet with aluminum strips as the coil and using a 120 volt household current. Proposing to solder an extension cord to the strip coil.
1. When it is plugged into the outlet, will it automatically send juice through the coil? or does it have to be triggered someway like an appliance's on & off switch? If it DOES have to be triggered, how do I do that?
2. I'm ordering some aluminum strips that are advertised to withstand up to 500 volts d.c.. The seller says he needs the minimum & maximum resistance (ohms) since the strip thickness depends on it. How would I determine the resistance based on 120 house hold volts? (I'd really like it to have a capability of withstanding up to 450 volts) Thanks.
Please be careful with whatever you are doing. I don't understand what you are trying to make (with aluminum strips?), and it doesn't sound like you've worked with AC mains power before. AC mains power is very dangerous, and you can start a fire or electrocute somebody pretty easily.
What are you going to use the electromagnet for? Are you familiar at all with UL standards for safety in electrical appliances? Do you know how to fuse an appliance that is going to be plugged into an AC mains outlet? What are the UL regulations for insulation, grounding, etc., that apply to the electromagnet that you want to build?
Just be careful when dealing with mains power with your lack of experience.
(1) That depends on how you build your circuit. If there is a closed path i.e. no switch\closed switch; then current will flow through the coil.
I hesitate to tell you more though as the mentors may get angry.
edit: berkedude covered the safety issues pretty good. Listen to him; its in your best interest :)
I don't know too much about what you're trying to do, but please take every precaution as the others mentioned. You really should get familiar with low-power magnets run from batteries before you even think about plugging into the mains. What on Earth do you want this thing for, anyhow?
I've never heard of aluminum strips being used. How are they insulated?
You're asking for all kinds of trouble experimenting with
direct AC mains powered electromagnets and
especially using aluminium strips for the coil!
You can't easily (at all) solder to aluminium.
The resistance will likely be very unstable due to
temperature as well as possible short circuits that may
be introduced in winding the thing.
You'll very likely either blow the circuit breaker or fuse
or will generate so much heat that the wires / strips will
start to melt which probably *will* cause the thing to short
out if it hadn't done so already.
Electromagnets work best on high current, and usually
don't require any kind of high voltage unless you have
large lengths (hundreds of feet) of very thin wire.
I'd suggest you get something like a 3V or 6V DC operated
motor or relay or 12V solenoid,
electromagnetic doorbell, or something like that
that's already got an efficient low voltage electromagnet
in it and tinker with that powered by a couple
of rechargable batteries or maybe a 2 amp 6 Volt isolated
DC power supply or so on. It'd be relatively a lot safer.
You can only get something like 20 Amps out of a
basic household AC circuit, so unless you had a 120V
circuit and something like 600 feet of 20 gauge wire
there'd be just no point whatsoever in using anywhere
near mains level voltage.
Even a common PC's power supply in the 500-600Watt
range would give you around 20 to 30 amps at 5V
which would be better suited to something like a
200 foot or so long coil of 12 gague copper wire.
That on an stout iron core would certainly be a fine
modestly strong electromagnet using a much safer
much lower voltage.
Of course there are relatively inexpensive permanent
magnets made from rare Earth materials out there for
just a few dollars each, and they're probably stronger
than almost any electromagnet one could hope to build
without a lot of engineering effort, and they don't need
power at all, though one must be respectful of their
strength and not get injured by their intense forces
of attraction!
Don't build any electromagnets that take more than
a few watts of power or more than 12 Volts of voltage
unless you've gotten solid information on how to be safe
with the voltages, currents, and heat levels that will be
produced by such a device!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
