Can an Infinitely Long Rod Spinning at Light Speed Exhibit Relativistic Effects?
The discussion centers around the theoretical implications of spinning an infinitely long rod at relativistic speeds, particularly examining the relativistic effects at each end of the rod. Participants explore concepts related to special relativity, including the potential for one end of the rod to exceed the speed of light and the implications for aging and information propagation between the ends of the rod.
  • One participant suggests that if a laser is swept quickly across a distant object, it can appear to move faster than light without violating any physical laws, prompting a hypothetical scenario with an infinitely long rod.
  • Another participant argues that a rod of negligible weight cannot exist, implying that any real rod would face physical limitations that prevent it from being spun at such speeds.
  • A third participant questions the feasibility of spinning a rod with minimal effort, suggesting the existence of an infinitely powerful machine to achieve this, while still seeking to understand the relativistic effects at each end of the rod.
  • A later reply emphasizes that the motion of one end of the rod is influenced by the motion at the other end only after the force has propagated through the rod, which occurs at the speed of sound in the material, always less than the speed of light.
Participants express differing views on the feasibility of the scenario, with some questioning the physical possibility of such a rod and others exploring the theoretical implications without reaching a consensus on the validity of the initial premise.
The discussion involves assumptions about the existence of an infinitely long rod and the implications of its rotation, which may not align with physical reality. There are also unresolved questions regarding the aging of the ends of the rod and the propagation of information between them.
rokimomi
Got this from extending the "faster than light" portion of the wiki page.
Wiki notes that if a laser is swept quickly across a distant object, the point will move faster, but nothing else necessarily violates any rules so this experiment passes.
Now what if you have an infinitely long rod of negligible weight opposing your holding of and swinging of the said rod, and you decide to spin it round and round at a 90 degree angle to your body.What are the SR effects at each end of the rod, particularly, the end that would otherwise move faster than c if it weren't for that speed limit compared to the end you are holding.
Would it just be a connected twins paradox? And what of the apparent "ages" of the two ends of the rod. I know a rod doesn't "age", but if you were to compare the aging of the end you hold through time and a point very very far away, would it really be different or is there some linkage of information about their respective ages that prevents this (this last question may just be my over-thinking the situation)?
There is no such rod of negligible weight though, which I believe is important, because I don't believe it would be impossible to rotate any physically existent rod to behave in such a manner where its outer points would be rotating above c.
I'm definitely not one to argue but is your response a sound debate that would limit this experiment, not that I doubt what you say.
In essence, I want a rod that would pose little effort to spin even if amazingly long but if your hunch is actually the limitation then I guess can we imagine some infinitely powerful machine can rotate it?
Ignoring the particulars altogether, when the rod is good and going, what are the effects @ either end?
The direction this is going - "would a rod that violates the laws of physics violate the laws of physics" - will not be helpful in understanding things.
The motion of one end of a rod can only be affected by motion at the other end after this force has been propagated through the rod. The speed this is happens is the speed of sound in the rod, which is always less than the speed of light.
  • · Replies 28 ·
  • · Replies 35 ·
  • · Replies 52 ·
  • · Replies 26 ·
  • · Replies 19 ·
