Can anyone explain me the 4 diode Balanced modulator circuit
The discussion focuses on the operation of a 4 diode Double Sideband Suppressed Carrier (DSBSC) Balanced modulator circuit. The circuit utilizes a bridge configuration to produce an output signal that reflects the input modulation signal, with polarity changes dictated by a control voltage. This results in two symmetrical versions of the modulation signal, effectively mimicking conventional DSBAM without a carrier. Participants also expressed interest in finding IRC channels for real-time discussions on similar topics.
  • Understanding of DSBSC modulation techniques
  • Familiarity with diode bridge circuits
  • Knowledge of control voltage applications in modulation
  • Basic principles of signal processing
  • Research the operation of diode bridge circuits in modulation
  • Learn about DSBAM and its differences from DSBSC
  • Explore control voltage applications in electronic circuits
  • Investigate real-time communication platforms for technical discussions
Electronics engineers, communication system designers, and students studying modulation techniques will benefit from this discussion.
dexterdev
Hi,
Can anyone explain me the working of 4 diode DSBSC Balanced modulator circuit. ie how multiplication occurs when switching. The image is attached.
-Devanand T
dexterdev said:
Hi,
-Devanand T
Noddy description:
The bridge will produce an output version of the input signal that is 'either way up', depending on the polarity of the (high level) 'control voltage' across the carrier input.The way I have always looked at it is that the Carrier signal reverses the polarity of the Modulation input signal twice every carrier cycle, so the resulting signal will appear as two symmetrical versions of the modulation signal; one inverted and one the right way up - i.e like conventional DSBAM but without any carrier to 'separate' the top and bottom halves of the envelope.
thank you sir
Did that make sense, then? I wasn't sure!
Sir, I got an explanation from Fresnel's Ppls of commn book...that was satisfactory... Thanks for your effort..In between I want to know any IRC channel for this forum (or any similar)so that I can ask doubts live (using windows 7 os). Not that comfortable with chating in IRC although
I don't know of any IRC on PF - but don't discount the possibility. Post a question of the Computing forum. You may get lucky.
thank you sir
  • · Replies 23 ·
  • · Replies 35 ·
