Can C be measured in MeV? If so is this per photon?
  • Thread starter Thread starter EMFsmith
    Per Photon
C, or the speed of light, cannot be measured in MeV, as MeV is a unit of energy while C is a speed measured in meters per second. Particle accelerators aim to accelerate particles to high speeds, which correlates with high kinetic energy, allowing for the creation of new particles. The energy required to accelerate heavier particles increases due to their mass, meaning that different masses require different amounts of energy to reach significant speeds. Additionally, no particle with mass can achieve the speed of light, as the equations governing motion break down at that point. The discussion highlights the distinction between energy and speed in the context of particle physics.
EMFsmith
Can C be measured in MeV?? If so is this per photon?
Basically as the title states, can you measure C in MeV, i read ALICE was nearing Acceleration of C at 14 MeV (These numbers are what i can remember from a while ago).
Then is that measure of 14 MeV for say a single atom, or does it apply for larger objects (More mass needs more energy to move it so i think not but i may as well ask)?
Oh wait, nothing can move at C can it because it hass mass.
Im starting to think, bad things usually ensue.
Any help would be great folks. :smile:
Science news on Phys.org
No, not really.
MeV is a unit of energy, with the dimension of joule and c is a speed and has the dimension of meters per second.
However, the whole point of a particle accelerator is to accelerate particles to high speeds. The reason is that high speeds means high energy (kinetic energy) and this energy can then be used to for example create other particles.
Hence, if you know the energy of a particle (in for example MeV) and you know its mass you can quite easily calculate its speed.
This is why particle physicists talk about accelerating particles to a certain energy.
Also, note that the equations break down if you try to set the speed of a particle to c, this means that there is no energy that corresponds to c.
You are confusing energy (i.e. the kinetic energy) with speed (c).
Zz.
So the heavier elements need higher MeV to reach higher acceleration, is this why you can't just keep combining elements like ununoctium to create super heavy elements?
Im guessing they would be ridiculously unstable anyway but that's for another post i think.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
