Can complex numbers be used in Fortran array constructors?
5 replies · 9K views
Lukejambo
Hi, so I need to write a fortran code with 2, 2x2 matrices.
These matrices are in the form of B=(1 exp(i)(theta) 0 0) and D=(0 0 exp(i)(theta) 1) where i is sqrt of -1 and theta is an angle between 0 and 2pi.
I've expanded the exponential so it reads cos(theta)+isin(theta) and let theta=pi/2
I've delcared i as complex in the form of i=(0.0,1.0) however as the matrices are declared as real with real components in them (ie: 0.0, 1.0) an error appears stating that "You cannot mix types in an array constructor (Complex(Kind=1)) in a real(Kind=1) constructor."
Is it possible to mix types in an array constructor or can I have the whole array as complex?
Any help would be much appreciated.
on Phys.org
No, you can't mix types in an array. Make the base type of the array COMPLEX.
Also, Fortran's generic EXP function accommodates the COMPLEX data type, so you can do stuff like this:
Code:
      complex i, z
      real theta
      i = (0.0, 1.0)
      theta = 0.5
      z = exp (i*theta)
      print *, z
      end
No need to use Euler's identity to calculate the real and imaginary parts separately.
Thanks for your help, I've declared each matrix as complex and used exp(i)(theta) instead of cos and sine however the problem still remains, here is my programme below:
program
implicit none
REAL, PARAMETER :: pi=3.14159
real :: ph
complex, dimension(2,2) :: B, D
complex :: z, ic
ph= 1.0
ic = ( 0.0, 1.0 )
z = exp(ic*ph)
B = RESHAPE( (/ 1.0, z ,0.0,0.0 /), (/2.0,2.0/) )
D = RESHAPE( (/ 0.0,0.0,z,1.0 /), (/2.0,2.0/) )
write(6,'(2f4.1)') B, D
end program
Is it because I'm using 1.0 and 0.0 as real values inside a complex array?
If so, can I convert them so they're complex numbers?
Thank you, that works!
