Can Degenerate Laurent Series Converge in Non-Standard Regions?
  • Context: Graduate
  • Thread starter Thread starter Josh Swanson
    Laurent series Series
The discussion revolves around the convergence properties of degenerate Laurent series, specifically examining the conditions under which the series converges in non-standard regions, such as annuli. Participants explore the implications of convergence for the upper and lower sums of the series and question the necessity of certain convergence requirements in existing literature.
  • One participant proposes that if a Laurent series converges in an annulus, then certain inequalities regarding the radii of convergence must hold: r_0 ≤ r < R ≤ R_0.
  • Another participant agrees with this assertion and suggests that it can be proven using properties of power series and convergence tests.
  • However, a different participant challenges the claim that L(z) converges for all |z| > |z_0|, arguing that outside the radius of convergence, the nth terms of a power series do not necessarily approach zero.
  • Further, a participant raises concerns about the justification for the limit condition involving the coefficients of the series, suggesting that the argument requires more rigorous support.
  • Another participant elaborates on the implications of the nth term test and explores the consequences of assuming certain limits on the coefficients, leading to a contradiction under specific conditions.
Participants express differing views on the convergence properties of the series and the necessity of certain conditions. While some agree on the implications of the convergence inequalities, others challenge the assumptions and reasoning behind them, indicating that the discussion remains unresolved.
Participants note that the nth term test's application requires careful justification, and there are unresolved aspects regarding the behavior of coefficients in the series. The discussion highlights the complexity of convergence in degenerate Laurent series and the potential for divergent behavior in certain regions.
Josh Swanson
Suppose we have
[tex]f(z) = \sum_{n=-\infty}^\infty c_n z^n; \quad U(z) = \sum_{n=0}^\infty c_n z^n; \quad L(z) = \sum_{n=1}^\infty c_{-n} z^{-n}[/tex]
where [itex]f(z)[/itex] converges* in the interior of some annulus with inner radius [itex]r[/itex] and outer radius [itex]R > r[/itex]. Further suppose [itex]U(z)[/itex] has radius of convergence [itex]R_0[/itex] and [itex]L(1/z)[/itex] has radius of convergence [itex]1/r_0[/itex], so [itex]L(z)[/itex] converges for [itex]|z| > r_0[/itex]. Must it be the case that [itex]r_0 \leq r < R \leq R_0[/itex]? Obviously the sum over all integers converges for [itex]r_0 < |z| < R_0[/itex] (if any such z exist), but for instance what happens if [itex]R_0 < r_0[/itex]? It's conceivable that the upper and lower sums both individually diverge, but that their combined sum still converges. It doesn't seem possible to me for this case to actually occur on a non-empty open set like an annulus... but I dunno.
For instance, where does
[tex]... + \frac{1}{2^3} \frac{1}{z^3} + \frac{1}{2^2} \frac{1}{z^2} + \frac{1}{2} \frac{1}{z} + 1 + z + z^2 + z^3 + ...[/tex]
converge?
This question came about in the context of the uniqueness of Laurent series. It seems that Laurent series are typically assumed to only be defined where their upper and lower sums converge, which sidesteps this issue. Each source I've looked at (Rudin's Real and Complex Analysis; Wikipedia; MathWorld; http://www.math.binghamton.edu/sabalka/teaching/09Spring375/Chapter8.pdf) at best includes this requirement implicitly and at worst ignores it entirely which makes me wonder if it's really necessary.
*I'm interpreting [itex]\sum_{n=-\infty}^\infty c_n z^n[/itex] as [itex]\lim_{N \rightarrow \infty} \sum_{n=-N}^N c_n z^n[/itex].
Must it be the case that [itex]r_0\le r < R \le R_0[/itex]?
Yes.
You can prove it playing a bit with power series. For example, take any [itex]z_0[/itex], [itex]r<|z_0|<R[/itex]. This implies that [itex]c_n|z_0|^n \to 0[/itex] as [itex]n\to \pm\infty[/itex], so the sequence [itex]c_n|z_0|^n[/itex] is bounded.
Comparison with geometric series gives that [itex]L(z)[/itex] converges for all [itex]|z|> |z_0|[/itex]. Since [itex]U(z) =f(z) - L(z)[/itex], then [itex]U(z)[/itex] converges for all [itex]z[/itex], [itex]|z_0|< |z|<R[/itex] as difference of 2 convergence series (both f(z) and L(z) converge in this annulus).
But power series (with positive powers) converge in a disc, so U(z) converges for [itex]|z|<R[/itex]. Then [itex]L(z) =f(z) - U(z)[/itex] converges in the annulus [itex]r< |z|<R[/itex] (f(z) converges in the annulus, L(z) converges in the disc [itex]|z|<R[/itex]). Then using comparison test we can concluyde that [itex]L(z)[/itex] converges for all [itex]|z|>r[/itex].
I don't see how this is true, though you made me consider the fact that the nth term goes to 0 on this annulus, which gives the result anyway.
Outside the radius of convergence of a power series, the nth terms do not go to 0 (which is how divergence is proven there), so each [itex]r < z < R[/itex] is not outside the radius of convergence of [itex]U(z)[/itex], so [itex]R_0 \ge R[/itex]. The lower bound is similar.
It occurred to me there are some details missing yet. Hawkeye's statement, essentially
[itex]\lim_{n \rightarrow \pm \infty} c_n z^n \rightarrow 0[/itex]
on the annulus of convergence, requires some justification. The nth term test only gives
[tex]\lim_{n \rightarrow \infty} c_n z^n + c_{-n} z^{-n} = 0 \mbox{ for } r < |z| < R \quad \mbox{ (*)}[/tex]
which is not a priori the same. Suppose for now that [itex]|z| = 1[/itex] satisfies the above. Putting [itex]z=1, i[/itex] into (*) and simplifying gives
[tex]\lim_{k \rightarrow \infty} c_{2k+1} + c_{-2k-1} = \lim_{k \rightarrow \infty} c_{2k+1} - c_{-2k-1} = 0[/tex]
so that [itex]\lim_{k \rightarrow \infty} c_{2k+1} = 0[/itex]. Thus [itex]\liminf_{n \rightarrow \infty} |c_n| = 0[/itex]. Suppose to the contrary [itex]\limsup_{n \rightarrow \infty} |c_n| > 0[/itex]. There is some subsequence [itex]\{|c_{n_k}|\}[/itex] where [itex]\lim_{k \rightarrow \infty} |c_{n_k}| = a > 0[/itex]. Cutting off finitely many terms, this constrains [itex]\{c_{n_k}\}[/itex] to lie on a compact annulus not containing the origin, so the subsequence has a limit point [itex]c[/itex] in this annulus. Passing to a further subsequence, we may then take
[tex]\lim_{k \rightarrow \infty} c_{n_k} = c \ne 0[/tex]
Applying (*) with this subsequence and [itex]z=1[/itex] gives [itex]\lim_{k \rightarrow \infty} c_{n_k} + c_{-n_k} = 0 \Rightarrow \lim_{k \rightarrow \infty} c_{-n_k} = -c[/itex]. Taking [itex]z = e^{it}[/itex] in (*) gives
[tex]\lim_{k \rightarrow \infty} c_{n_k} e^{i n_k t} + c_{-n_k} e^{-i n_k t} = 0[/tex]
[tex]\Rightarrow \lim_{k \rightarrow \infty} c_{n_k} e^{2i n_k t} + c_{-n_k} = 0[/tex]
[tex]\Rightarrow \lim_{k \rightarrow \infty} c_{n_k} e^{2i n_k t} = -(-c) = c[/tex]
[tex]\Rightarrow \lim_{k \rightarrow \infty} e^{2i n_k t} = c/c = 1[/tex]
This last line is obviously nonsense, for instance with [itex]t=\pi/2[/itex], so [itex]\lim_{n \rightarrow \infty} c_n = 0 = \lim_{n \rightarrow \infty} c_n z^n[/itex] after all, which forces [itex]\lim_{n \rightarrow \infty} c_{-n} z^{-n} = 0[/itex]. We may peel back the [itex]|z| = 1[/itex] assumption by applying the above to [itex]z / |z|[/itex].
