How can we derive the value of energy in rest mass and the relationship to c^2?
  • Context: High School
  • Thread starter Thread starter alba
    E=mc^2
The discussion revolves around the derivation of the energy associated with rest mass and its relationship to the speed of light squared (c²). Participants explore various interpretations of Einstein's formula E=mc², the implications of scalar values in physics, and the validity of different prefactors in energy equations. The conversation touches on theoretical, conceptual, and historical aspects of the topic.
  • Historical
  • Some participants question the logical derivation of the scalar value of energy in rest mass, comparing it to arbitrary characteristics like the number of fingers on a human.
  • Others argue that relativistic considerations change the dynamics of mass and energy, suggesting that mass is not constant and is dependent on velocity.
  • One participant emphasizes that physics operates on theories rather than proofs, asserting that E=mc² is consistent with numerous experiments and fits within the framework of special relativity.
  • There is a discussion about the implications of changing the definition of energy units, with some arguing that such changes would complicate existing formulas without altering the underlying physics.
  • Participants express differing views on the significance of prefactors in energy equations, with some suggesting that any prefactor could be valid depending on unit definitions.
  • Some participants highlight that the scalar nature of energy does not imply it is unrelated to other physical concepts, questioning the assumptions that lead to specific energy values like 0.511 MeV for electrons.
  • There is a call for evidence to support claims about the correctness of specific prefactors and the derivation of energy values.
The discussion remains unresolved, with multiple competing views on the derivation of energy values, the significance of prefactors, and the nature of mass in relativistic contexts. Participants express differing opinions on the implications of changing energy units and the validity of various interpretations of Einstein's work.
Participants reference historical accounts and the evolution of energy concepts, indicating that the discussion is influenced by both theoretical frameworks and empirical observations. There are unresolved assumptions regarding the definitions of energy and mass, as well as the implications of relativistic effects.
alba
I have read different version/interpretations of Einstein derivation of the formula, no one is logically satisfying.
But my question is more general: the value of energy in rest mass is a scalar, which is not related to anything, how can we use logic or math to derive such a value? Stretching it a bit to make myself clear, how can you derive the number of fingers in a human being? There is sure anarcane reason, but that is the way Nature decided and has it, how can you prove/derive it if you have no direct acces to it?
Because of annihilation we knew that it is in the region of c^2, but many coefficients have been suggested and they are all right or wrong, depending on the init of energy we choose. They choose to adopt that value to honour him, but I read that he himself had suggested the factor of 1/2, and when he was accused of plagiarism, he changed it to 1. If there were a compelling reason or rationale, you do not change it overnight.
Due to relativistic considerartion the whole kinematics and dynamics changes. Three is nothing like this that there is annihilation region where it works and for ordinary events it does not. It works but the difference is too very small. When you apply force on a a particle it increases its speed and also its mass.. F = dP/dt with P = mv and m is a function of time and not constant; and not F = m*(dv/dt). We are not adding fingers to our hand but just stating that mass and energy are equivalent and if a particles energy is increasing then its mass is also increasing such that the total energy = mc^2 where m is the instantaneous mass.
Proofs are something in mathematics. Physics does not have proofs, it has theories.
E=mc2 as rest energy is consistent with literally tens of thousands of experiments, and it fits to the framework of special relativity. A prefactor of 1/2 would be completely inconsistent with experiments. A prefactor like 1.0000000000001 would not directly be in disagreement with observations, but it would not fit into special relativity - which has been tested extremely well. There is no consistent theory that would have a different prefactor.
This is pure nonsense.@Let'sthink: The concept of a "relativistic mass" (velocity-dependent mass) is not used in physics any more.
Thanks for refuting let'sthink
No proof, what is a derivation, then? They all talk of Einstain derivation of the formula, don't they?
You ignored my post, if they had chosen the joule as twice its current value, then the factor is 1/2, right?
You can derive it from certain assumptions. The fact that nuclear reactors work strongly suggests that those assumptions are valid.
No. One way to decrease the value of the Joule would be to decrease the value of the kilogram. Then no factor of two is needed.
If you only change the Joule then you no longer have an equation because the units don't match. So you need to add a factor of (1/2)J'/J (where J' is your new unit), not just a half.
There's no way to make a dimensionless 1/2 just appear in the equation.
Ibix said:
Y
1/2 joule is the Ke of 1 Kg at 1m/s. You can have the joule with the Ke of 1 Kg at any velocity, you can have any value of the factor. The same applies if you refer the joule to gravity
You can use mathematics to derive things within a given physical theory: "If assumptions A,B,C are true, then [calculation] we predict XYZ". You cannot prove that A, B and C are true. You can only observe that this assumption leads to great predictions.
The formula is independent of any unit system.
You can replace all occurrences of "E" in all formulas by "E/2" or "2E", but where is the point? You would not change physics at all, but you would make many formulas more complicated than necessary. You can do the same independently for the definition of a Joule, but again, there is no point. The current Joule definition is convenient.
There was an actual discussion about that at the time the concept of energy was introduced, because kinetic energy in nonrelativistic mechanic has this 1/2 prefactor in E=1/2 m v2. You could change this, if you also change all other formulas - it is purely a convention to use the current energy concept. This was centuries before special relativity was developed.
But, as I said in the post you quoted, many equations will then be invalid unless you add a conversion factor with units. You are essentially making a daft choice of units then undoing the daftness. You aren't multiplying by an arbitrary constant which is what you were accusing Einstein of.
alba said:
...the value of energy in rest mass is a scalar, which is not related to anything, how can we use logic or math to derive such a value?
Just because something is scalar doesn't mean it is "not related to anything" - otherwise, you could never find a scalar in an equation!
It is not the fact of just being a scalar. To what theory/cause is it related ? what determines the fact that an electron has energy of .511 MeV? from what assumptions do you derive that?
That is not the purpose of my question, mfb.
The point I am making is that observation showed that energy is in the range of (k) c^2. They suggested various factors:1/2. 3/8 etc, then Einstein suggested 1, and everybody say he derived the formula. I am trying to say that any factor is right if you base your unit on that asssumption.
I am asking you to show evidence that the other factors are wrong, and that there are objective reason to prefer, or from which you derive that value. Did I make myself clear?
I made no daft choice since I made no choice, and I amnot accusing Einstein, either.You are accusingme without ground.
If you read the historical accounts, probably you understand what I am saying.
But my question is :
How do you derive that?
Can you derive that in the first place?
Can you address the specific questions?
From (a) the laws of physics are the same in every reference frame and (b) the speed of light is the same for all observers. Everything else follows from that, plus quantum field theory if you want to study things like annihilation reactions, and general relativity if you want to study gravity.
Why don't you start learning the basics of special relativity before you start threads like this one?
alba said:
The point I ammaking is that observation showed that energy is in the range of (k) c^2. They suggested various factors:1/2. 3/8 etc, then Einstain suggest 1 and everybody say he derived the formula.
This is just nonsense.
Feel free to ask questions, but don't make up nonsense.
You were proposing a daft choice of units then.
You said in your OP that I read that [Einstein] himself had suggested the factor of 1/2, and when he was accused of plagiarism, he changed it to 1, suggesting that Einstein had intellectual property problems, rather than that E=mc2/2 is wrong.
alba said:
But my question is :how do you derive that?
Here is a derivation that vanhees71 posted earlier today.
Forget what you consider nonsense, my question remains:
how do you derive that formula
I suppose it boils down to what is meant by a derivation. But since most textbooks on relativity have a derivation, I think you need to say what you don't understand/like/accept/(or whatever reason you have for this question) about the standard derivations.
Here's Einstein's paper where he derives it himself: https://www.fourmilab.ch/etexts/einstein/E_mc2/www/
Note that the units are not in kilograms and joules, but in ergs and grams. Also note the remark at the bottom of the page : the italicised sentence in the conclusion may be written as the equation "m = L/c²" which, using the more modern E instead of L to denote energy, may be trivially rewritten as "E = mc²".
Then either the "different versions" you've seen are incomplete or you are not yet able to understand it... Especially the impressions you leave by the rest of your posts, I tend to doubt your references [and since it's about Einstein and such a basic equation, the probability that you found yourself reading some crackpot's article is high]...
This thread is closed until a specific reference can be produced which meets PF standards but is not "logically satisfying".
E=mc^2 is correct (no factor of 1/2 etc) in any system of units in which the units of mass, length, and time are consistent with Newton's laws.
  • · Replies 55 ·
  • · Replies 62 ·
  • · Replies 22 ·
