Can electronegativity be the same for 2 elements?
Sulfur and Iodine both have an electronegativity value of 2.5, indicating that they form a nonpolar covalent bond in compounds like SI2. This means that the shared electrons spend equal time around both atoms, as the difference in electronegativity is zero (2.5 - 2.5 = 0). While some sources may present slight variations in electronegativity values, the consensus is that for practical purposes, the electronegativities are effectively the same, leading to no partial charges in the bond.
  • Understanding of electronegativity and its measurement
  • Familiarity with covalent bonding concepts
  • Knowledge of polar vs. nonpolar bonds
  • Basic principles of atomic structure, including protons and atomic radius
  • Research the concept of electronegativity and its significance in chemical bonding
  • Explore the differences between polar and nonpolar covalent bonds
  • Study the impact of atomic structure on electronegativity values
  • Examine other examples of nonpolar covalent bonds in organic compounds
Chemistry students, educators, and professionals interested in understanding covalent bonding and electronegativity in chemical compounds.
supernova1203
Between Sulfur and Iodine, which has more Electronegativity? I read that they both have the same, if so how can i determine in SI2 compound around which atom do the shared electrons spend more with with(Since that is determined by which atom has greater electronegativity)
Or maybe they spend equal amounts of time around both atoms since electronegativity is the same?
this is with covalent boding by the way
Some charts say they're the same, others do not. The textbook I have states sulfur and iodine have an electronegativity of 2.5.
But yes your correct, the electrons spend an equal amount of time around both atoms. Remember, this bond is NON POLAR covalent since the electronegativities equal 0 (2.5-2.5=0). Therefore, neither has the partial positive/negative charge.
no it can't happen
electonegativity must be different for element to another
because the number of protons,electrons,atomic radius and number of energie lvls are different between elemnts.
the problem is that some numbers are very close like (2.489347458 and 2.497483834) well, those long numbers are approximated.(2.5 and 2.5)
in the case of Sulfur and Iodine difrence of electonegativity is very small -> nonpolar covalent bond (same->most of oraganic compound C-H )
so the electrons spend a bit longer time around the more electronegative element (u must have the original number)
  • · Replies 34 ·
9K
