Can energy be negative or can just a change in energy be negative?
Energy can be negative, particularly in the context of gravitational potential energy (GPE), which is defined relative to a reference point. In a star-satellite system, the mechanical energy can be negative when the gravitational potential energy is considered zero at infinite separation. The change in potential energy is crucial, as it depends on the chosen reference point, such as U(0)=0 or U(h)=0, leading to different interpretations of energy values.
  • Understanding of gravitational potential energy (GPE)
  • Familiarity with reference points in physics
  • Basic knowledge of mechanical energy concepts
  • Ability to manipulate equations involving potential energy
  • Study the concept of reference points in gravitational potential energy
  • Learn about the implications of negative energy in astrophysical systems
  • Explore the mathematical derivation of potential energy equations
  • Investigate the relationship between kinetic and potential energy in mechanical systems
Students of physics, educators teaching mechanics, and anyone interested in the principles of energy in astrophysics.
Jaccobtw
I'm reading my text book about the gravitational potential energy of a satellite-star system. It says 'The mechanical energy of a star-satellite system can be negative because gpe is always negative when we let the gpe be zero at infinite separation.
None
It sounds like the book is contradicting itself or I just don't understand something fundamental. How can energy be negative? Thank you
Potential energy is relative to some datum, so it can be positive, negative or zero.
Potential energy is defined based on a reference point. So you are really looking at a change in potential energy. For example, if you simply look at a potential energy like ##U(x) = mgx##. This comes from letting U(0)=0 be a reference point. If you let U(h) = 0, then ##U(x) = mg(x-h)##. But if you look at the change in potential energy from two points, the second definition will give ##U(h_2)-U(h_1)=mg(h_2-h)-mg(h_1-h)=mgh_2-mgh_1##, which is consistent with the change in potential energy of the first point.
For gravitational potential energy, it is easiest to let the reference point be at ##x\rightarrow \infty##, since it gives you an additional zero instead of a constant.
  • · Replies 17 ·
