Can I use a bigger radiator in place of a smaller radiator?
  • Thread starter Thread starter Shivam2112
    Radiator
The discussion centers around the implications of upgrading to a larger radiator in a project formula car, specifically transitioning from a bike radiator to a car radiator while maintaining the same engine and pump. Participants explore potential drawbacks and considerations related to this modification.
  • Homework-related
  • Some participants express concerns that a larger radiator might prevent the coolant from reaching the optimal temperature range for the engine.
  • Others suggest that an oversized radiator could occupy space that might be better utilized for other components in the car.
  • There is a request for assistance with calculations and reports related to the radiator upgrade, with some participants emphasizing the need for the original poster to demonstrate their own attempts at solving the problem.
  • One participant references a previous thread about using two small radiators in parallel, indicating that the current discussion is distinct as it focuses on a single larger radiator.
Participants do not reach a consensus on the implications of using a larger radiator, as concerns about temperature regulation and space utilization are raised without definitive resolutions. There is also disagreement regarding the nature of the original poster's inquiry, with some framing it as schoolwork while others clarify it is for a project submission.
Participants note the importance of showing attempts at calculations and understanding the implications of the radiator size, suggesting that the discussion is contingent on the specific requirements of the project and the design constraints of the formula car.
This discussion may be useful for students or enthusiasts involved in automotive engineering projects, particularly those working on cooling system design and modifications in competitive environments.
Shivam2112
Thread moved from the technical forums, so no Homework Template is shown
I want to upgrade my radiator to a bigger one in my project formula car,with the same engine and pump, what are the cons of it.
Probably going to upgrade from a bike radiator to a car radiator.
Also please help with calculations and reports.
What reports? Is this for schoolwork?
No sir,this is not for school work, the reports consists of basic information and calculation of the radiator, these reports are submitted to the committee of judges of the student formula ,in which I am takin part in.
It is still school work. We need you to show your own attempt at answering the question. We help, but we do not do your work for you.
Ohk sir
The main downside I see is that a too large radiator might prevent the coolant getting to the proper temperature range for the engine. Also, if the radiator is larger than really needed, it could take up space that might be better used for some other component.
We will help you do the calculations, but we won't do them for you -- that's not our job.
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 26 ·
