Can my dining table hold four times its weight before tipping?
  • Context: Undergrad
  • Thread starter Thread starter Jonbarnes
    Stability Table
The discussion revolves around the structural integrity of a dining table and its ability to support weight at the edge without tipping over. Participants explore the mechanics involved in determining the tipping point, considering factors such as the placement of the legs and the distribution of weight.
  • One participant seeks to understand how much weight can be applied at the edge of the table before tipping occurs, given the legs are set in about one quarter of the total width of the top.
  • Another participant suggests determining the pivot point at the legs and balancing the moments of the weight applied and the weight of the table, assuming the table's weight is concentrated at its center.
  • A participant questions whether a weight equal to the table's weight would be sufficient to tip it when applied at the outer edge, considering the cantilevered portion of the table on the opposite side.
  • Further suggestions include making the table's weight equal to that of a guest, moving the legs closer to the edge, or considering the position of a person sitting on the table.
  • One participant concludes that a significant weight at the edge would be needed to tip the table, noting that normal physiques could sit further in without causing tipping, and mentions the possibility of increasing the table's mass by filling the legs with sand.
Participants express various viewpoints on the mechanics of tipping, with no consensus reached on the exact calculations or methods to ensure stability. Multiple competing views on the factors influencing tipping remain present.
Assumptions about weight distribution, the placement of legs, and the effects of additional mass are discussed, but these factors remain unresolved and depend on specific design choices.
Jonbarnes
Hi - I'm designing a dining table, and am trying to calculate how much weight could be applied at the edge of the table (if someone were to lean or sit on it) before it would tip. If the legs are set in about one quarter of the total width of the top, can the outer edge of the table carry a weight (including the overhang) of four times the static weight of rest of the table (on the other side of the leg) before it will tip? It seems that people sit on tables round here more often than we eat at them, so I'm keen to figure this out before I go much further with the construction. Any help is greatly appreciated.
Determine the pivot point of the table (where the legs are). Then balance the moments of people and the table. For practical purposes, the weight of the table could be assumed to be concentrated at its center.
Thanks for the reply - given that the pivot point (leg location) is mid-way between the edge of the table and the center of the table, does this mean that a weight the same as the table itself would be sufficient to tip the table, if applied at the outside edge (unlikely in reality, I know)...what about the rest of the table that cantilevers beyond the center on the other side - is this not relevant?
Yes, if the legs are half way between the center and edge. You have a few choices to improve this:
(a) Make the table the same weight as your guest sitting on it.
(b) Move the legs closer to the edge.
(c) Assume people put their rear end half way between the edge and leg.
Excellent, and thanks again. If my calculations are correct, it'd take a pretty burly guy right at the edge to make it tip. A couple of more normal physiques could perch a little further in without incident, and I can also fill the rather large leg members with sand to increase the mass of the table. Other than this, I can try to prevent excessive perching. A splayed foot would help, but I'd rather not...
  • · Replies 42 ·
11K
11K
9K
