Can Resistors Be Used in A/C Circuits?
  • Thread starter Thread starter DkEnrgyFrk
    Circuit Resistor
The discussion centers on the use of resistors in alternating current (A/C) circuits, exploring whether traditional resistors can function in such environments and the distinctions between different types of resistive components like potentiometers and rheostats. Participants examine practical applications and theoretical considerations related to resistors in A/C systems.
  • One participant expresses uncertainty about the use of resistors in A/C circuits, suggesting that power adapters may be necessary for proper function.
  • Another participant asserts that the basic role of resistors in A/C circuits is to limit current flow, providing examples of rheostats used in fan speed controllers.
  • Discussion includes the function of A/C amplifiers and power supplies, indicating that resistors are utilized in various electronic applications.
  • Concerns are raised about the maximum voltage that resistors can handle, with a warning about potential damage if exceeded.
  • Some participants discuss the differences between potentiometers and rheostats, questioning their applicability in A/C versus D/C circuits.
  • Clarifications are made regarding the use of rheostats in high power applications, with both types of resistive components being applicable in A/C and D/C contexts.
Participants generally agree that resistors can be used in A/C circuits, but there is no consensus on the specifics of their application or the distinctions between different types of resistors. Multiple competing views on the roles and definitions of resistive components remain present.
Participants mention various applications and configurations of resistors in A/C circuits, but there are unresolved questions about the conditions under which different types of resistors operate effectively. The discussion also highlights potential misconceptions about the interchangeability of components in A/C and D/C applications.
This discussion may be useful for individuals interested in electronics, particularly those exploring the roles of resistive components in different types of circuits, as well as those seeking clarification on the distinctions between various resistive devices.
DkEnrgyFrk
I thought that resistors, like the ones that I buy at RadioShack, could only be used on D/C circuits. I was looking up how to's on electromagnets and found a thread that mentioned using resistors with A/C power.
The thread was on this forum but I can't find it now.
I am guessing that the post was being very vague and that a power adapter must have been used in the circuit. Not just a resistor.
A power adapter, like the ones for USB devices and pc power supplies aren't just transforming the voltage by downgrading it to a lower voltage, they are converting it to DC as well, right?
So I'm guessing that that was forgotten to be mentioned.
Or are there resistors that are used in A/C circuits? Well, I mean, true resistors, not lamps, etc.
Basic role of resistor remains same in AC circuits as well - to limit the current flow.
An easy example : I remember we used to have rheostat type of speed controllers for fans when I was a kid.
The good old ac/dc adapters use transformers to step down ac voltage and then rectify it using diodes. They usually also contain a capacitor as ripple filter.
Now in some mobile charger circuits, I am seeing a smaller adapter circuit which does not require transformers. Basically they use a large wattage resistor to drop the current from AC. then feed it to a bridge rectifier. the output voltage is controlled using a zener diode.
Audio is also AC, of a sort.
AC amplifiers are central to electronics, and they use every part you can think of.
There are also AC power supplies such as inverters and UPS.
I am a moderator for AllAboutElectronics.com, a teaching website for electronics. Look for Bill_Marsden .
resistors are passive components and do not care what kind of voltage is applied, just what the MAX voltage is (overdo it and they'll start to burn --- overdo it enough and they'll explode)
That's a good example. I thought potentiometers were used in DC circuits only and rheostats were used in A/C circuits only. This a good example of parts that can't mingle between the two types of power?
And just what do you think is the difference between a "potentiomenter" and a "rheostat" and how do you see that making ANY difference in whether you put DC or AC across them?
In practice today, you'll find the term "rheostat" is used in high power applications, such as motors. A rheostat can be used for AC or DC motor controllers. A potentiometer is typically a very low power device. It, too, can be used for AC or DC.
You'll find that most rheostats have only two terminals, essentially being a variable resistor, whereas the potentiometer with its sliding tap must have three terminals.
(There is another altogether different electrical apparatus named a "potentiometer". )
  • · Replies 18 ·
