Can Someone Explain This Change of Variable?
The discussion centers on the change of variable in the integral involving the boundary of a ball, specifically how the surface measure dS changes from dS(y) to dS(z). The reasoning suggests that since the integral is averaging values over the surface, the specific radius does not affect the outcome, allowing the transition to the unit ball. It is noted that the transformation shifts the center of integration without altering the average value being computed. Concerns are raised about the implications of varying radii, particularly when r exceeds 1, but it is clarified that the constant radius can be factored out of the integral. Overall, the change of variable is justified by the averaging nature of the integral.
mmmboh
\frac{1}{|\partial B(x,r)|}\int_{\partial B(x,r)}u(y)\,dS(y)=\frac{1}{|\partial B(0,1)|}\int_{\partial B(0,1)} u(x+rz)\,dS(z)
Why does dS(y)\to dS(z) and not dS(y)\to dS(x+rz)?
If you want more information, it comes from http://www.stanford.edu/class/math220b/handouts/laplace.pdf on page 8, it's used to prove the mean value formula for the laplacian.
Is it because it doesn't matter what radius the surface we are integrating over is because we are taking the average?
The notation \partial B(x,r) refers to the boundary of the ball of radius r with centre x, i.e. the sphere of radius r with centre x. All the change of variables is doing, is moving to the point x and rescaling so you're only integrating over the unit ball. Suppose that \mathbf{y}\mapsto x+r\mathbf{z} with \| \mathbf{z} \| =1.
So your question is just saying that the centre of the integration is just be been shifted.
Good set of notes by the way.
Does this only work because we are taking the average? Because if r>1, then dS(y) would be larger than dS(z), right? And so the left integral (without taking the average) would be larger than the right integral (without taking the average)...
You're integrating over the sphere, I think that as the radius if the sphere is constant, it can just be taken outside of the integral.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
