Can someone solve this complex number equation for x and y
The discussion revolves around solving a complex number equation involving real quantities x and y. Participants explore various methods to isolate x and y from the equation, which leads to polynomial forms that require further manipulation.
  • One participant presents the equation (ix)(1+iy)=(3x+i4)/(x+3y) and expresses difficulty in isolating x and y.
  • Another participant suggests showing the work done so far to facilitate further discussion.
  • A participant details their approach of rationalizing the left-hand fraction and grouping real and imaginary parts, leading to two equations based on the equality of real and imaginary components.
  • Another participant proposes a cross-multiplication method, simplifying the equation to (4y-3x) + (x² - 4)i = 0, indicating a potential mistake in the previous approach.
  • One participant notes that the equations can be expressed as polynomials and suggests a relationship y=(3/4)x to eliminate y in one of the equations for solving x.
Participants present multiple approaches and methods for solving the equation, indicating that there is no consensus on a single method or solution. Disagreements about the correctness of specific steps and the identification of potential mistakes remain unresolved.
Participants express various assumptions and dependencies on the manipulation of complex numbers and polynomials, but these aspects are not fully resolved within the discussion.
anjunawoop
If x and y are real quantities what are the solutions for x and y
I have tried grouping the equation into two equal complex numbers but have failed to find a solution which isolates x and y from the two quite long polynomial equations.
Does anybody know how to do this.
Your approach sounds fine. Show us what you did so far.
(xi)/(1 + yi) = (3x + 4i)/(x + 3y)
First rationalized the left hand fraction.
(xi)/(1 + yi) * (1 - yi)/(1 - yi) = (xi -yxi^2)/(1 + y^2)
= (yx + xi)/(1 + y^2)
Grouped real and imaginary terms
[ yx/(1 + y^2) ] + [ x/(1 + y^2) ]i
Then grouped real and imaginary terms on the right hand fraction
(3x + 4i)/(x + 3y) = [ 3x/(x + 3y) ] + [ 4/(x + 3y) ]i
Set the two complex numbers equal
[ yx/(1 + y^2) ] + [ x/(1 +y^2) ]i = [ 3x/(x + 3y) ] + [ 4/(x +3y) ]i
Take the two imaginary parts to be identical
Take the two real parts to be identical
[ yx/(1 + y^2) ] = [ 3x/(x +3y) ]
[ x/(1 + y^2) ] = [ 4/(x + 3y) ]
Expressing both fractions as polynomials
(yx)(x + 3y) = (3x)(1 + y^2)
(x)(x + 3y) = (4)(1 + y^2)
Then multiplying out both equations in x and y
1. yx^2 + 3y^2x = 3x + 3xy^2
2. x^2 + 3yx = 4 +4y^2
Grouping terms on one side to form two equations that equal zero.
1. yx^2 + 3y^2x - 3x - 3xy^2 = 0
2. x^2 +3yx - 4 - 4y^2 = 0
Now trying to find some way of dealing with these terms.
Hmm, let's just cross multiply and simplify:
(xi)(x + 3y) = (3x + 4i)(1 + yi)
x²i + 3xyi = 3x + 4i + 3xyi - 4y
x²i = 3x + 4i - 4y
That doesn't look so bad does it?
I suspect you made a mistake somewhere, but I haven't figured out where yet.
Note that you can write these two equations as
\begin{align*}
\frac{x(x+3y)}{1+y^2} &= \frac{3x}{y} \\
\frac{x(x+3y)}{1+y^2} &= 4
\end{align*}So you have y=(3/4)x. You can plug use that to eliminate y in one of the equations and solve for x.
Or you can do it the way ILS did it.
  • · Replies 47 ·
  • · Replies 0 ·
  • · Replies 26 ·
