Nenad said:
ok, this is the way I was taught, that the fame in motion is the frame in which canges occur such as time dilation, mass dialtion and length contraction.
But the frames are in relative motion. Relativity teaches that either frame is perfectly entitled to view itself as being at rest.
I was also taught that in a case with two abservers, one of them will be wrong in his assumptions that he is in motion and not the other.
This is a serious misconception. Any inertial frame is just as good as another for the purpose of making observations. Relativity tells us that certain quantities (length, time, clock synchronization) are frame dependent. The Lorentz Transformations describe how the space-time coordinates of an event (and thus measurements of length and time) transform between frames.
So youre telling me that both observers are right, and they both end up agreeing in the end with nobody changing their mind.
Yes, both observers are "right" in the sense that their clocks and measuring sticks really do work according to SR. Whether they have to change their minds or not depends on their level of sophistication: Observers who understand SR
expect measurements to be different in different frames.
Hmm, this makes me think. But how would the time dilation work out for both observers?(twin paradox case) They will both assume that they are aging much more than the other observer, (as a result of their assumptions that the moving frames time is slowing down)?? Just help me with this example, I will get the rest from books.
Let's get this clear first: between inertial frames in relative motion, time dilation (and length contraction, and clock synchronization effects) work exactly the same for both observers.
The twin "paradox" -- which, by the way, has nothing to do with the example we've been discussing -- involves a little more analysis. I won't attempt it here; pick up any book on relativity. (David Hogg's book discusses it.) I'll just make a few comments that might help. The twins begin in one frame, but one remains in that frame while the other accelerates then rejoins that frame. That accelerating twin ends up traveling a different (curved) path through space-time--one that always has a shorter proper time.
Since one twin accelerates, he does not remain in a single inertial frame. So, you cannot simply apply SR from that twin's frame as if it did. But the view of the stay-at-home twin is always from a single inertial frame, so SR works just fine for him. He sees the other twin's clock as being slow. You can certainly analyze the twin paradox from both twin's viewpoints even within SR--but that involves the accelerating twin changing inertial frames at some point during his journey. But rest assured, a complete account of both twins unambiguously shows that they
both agree that the accelerated twin ends up younger. So, it's not that one is wrong and the other right: they are both right, and they both agree.
