Can these equations be solved analytically?
  • Context: Undergrad
  • Thread starter Thread starter lavoisier
6 replies · 2K views
lavoisier
Hi everyone,
I am studying a problem related to Bayesian probability, and I came across two equations, which as far as I can tell can only be solved numerically, but as I'm no expert I would like to hear your opinion, please.
The first one is:
[itex]P(a) \cdot \left[ 1 - \Phi \left( \frac {x - \mu_a} { \sqrt 2 \cdot \sigma_a} \right) \right] = (1 - P(a) ) \cdot \Phi \left( \frac {x-\mu_b} { \sqrt 2 \cdot \sigma_b} \right)[/itex]
where:
[itex]\Phi (y) = \frac {1} {\sqrt {2 \pi}} \cdot \int_{- \inf}^y {e^{-t^2 / 2}} \, dt = \frac 1 2 \cdot \left[ 1 + {erf} \left( \frac {y} {\sqrt 2} \right) \right][/itex]
P(a) is a probability, thus a real (?) number between 0 and 1, and I need to solve for x.
Initially I had no doubt that this could not be solved analytically for x. But then as I was reading something about statistical power, in an example they showed how you can invert Φ using a 'probit' function, so I wondered if it's possible after all. I would have thought the inversion required Φ to be 'isolated', and this didn't seem possible here. But I'd be glad to be proven wrong!
The second one is:
[itex]N \cdot P(a) = \sum_{i=1}^N {\frac {P(a) \cdot A_i} {P(a) \cdot A_i + [1-P(a)] \cdot B_i} }[/itex]
where P(a) is as above, N is a positive integer and:
[itex]A_i = 1 - \Phi \left( \frac {x_i - \mu_a} { \sqrt 2 \cdot \sigma_a} \right)[/itex]
[itex]B_i = \Phi \left( \frac {x_i - \mu_b} { \sqrt 2 \cdot \sigma_b} \right)[/itex]
and I need to solve for P(a).
If I understand correctly, Φ has the property:
[itex]\Phi (-x) = 1 - \Phi (x)[/itex]
but I don't see if/how that helps me in this case.
Any idea?
Thanks
L
micromass said:
It doesn't seem that a numerical solution is possible. And if it is possible, it's likely not really important anyway.
Unless I am much mistaken, a numerical solution is possible, and in fact I did solve both equations numerically for a given dataset of xi's with N ≈ 115000.
I solved the second one (Excel solver, minimisation of (rhs-lhs)2 ), and with the resulting value of P(a) (≈ 0.33%) I solved the first one (x ≈ 65).
My question was whether they were analytically solvable.
Not important, I guess you mean as in 'not a type of problem that is generally encountered in this branch of statistics', as opposed to 'who cares about this' :biggrin:
If so, I suppose I'd better review the chain of reasoning that led me to these equations.
PS: just spotted an error in my Tex. The square root of 2 shouldn't be there, it's already in the definition of Φ. Correct version:
[itex]P(a) \cdot \left[ 1 - \Phi \left( \frac {x - \mu_a} {\sigma_a} \right) \right] = (1 - P(a) ) \cdot \Phi \left( \frac {x-\mu_b} { \sigma_b} \right)[/itex]
[itex]A_i = 1 - \Phi \left( \frac {x_i - \mu_a} { \sigma_a} \right)[/itex]
[itex]B_i = \Phi \left( \frac {x_i - \mu_b} { \sigma_b} \right)[/itex]
OK, I understand, thanks.
I would have cared for an analytical solution, because while it's true that I do want the numbers in the end, without a closed form I'll have to write an iteration to solve the problem for each new dataset I get.
In the past someone else in these forums (@mfb) taught me that I could do an iteration (e.g. Newton) in Excel by just writing out the steps line by line, which worked very well. I'll see if I can do it in this case; much more complicated.
