Can this integral be done using elementary techniques?
4 replies · 2K views
Bipolarity
## \displaystyle \int \frac{dx}{(x^{2}+a^{2})^{3/2}} ##
A substitution does not seem to work. I know that a closed form solution exists however, just curious if it can be done by the standard techniques usually taught in calculus. Thanks!
BiP
The substitution [itex]x=asinh\theta[/itex] seems to work.
Edit: [itex]x=atan\theta[/itex] also works if you don't mind integrating the secant function.
Actually, you need to integrate cosine after that substitution. It may be the easiest way.
Goa'uld said:
Actually, the integrand simplifies to (cosθ)/a^2 after that substitution. It may be the easiest way.
You are right of course. Somehow I turned [itex]\frac{1}{sec\theta}[/itex] into [itex]\frac{1}{cos\theta}[/itex]
The presence of x2 + a2 in the denominator makes this integral a candidate for trig substitution. Same goes for the difference of squares, either x2 - a2 or a2 - x2.
What I do in these situations is draw a right triangle, and label the sides and hypotenuse according to whether I'm dealing with a sum of squares or a difference. If it's a sum of squares, as in this problem, I label the vertical side as x and the horizontal side as a. This means that the hypotenuse is √(x2 + a2). If θ is the angle across from x, then tanθ = x/a, so sec2θdθ = dx/a, or dx = asec2θdθ. After this, replace x and dx in the integral with θ and dθ and integrate.
A similar analysis can be done for either of the two differences of squares.
