Can Two 19-Liter Bottles Lift a 75kg Person Off the Ground?
  • Thread starter Thread starter Tristan77
    Rockets
The discussion revolves around the feasibility of using two 19-liter bottles to lift a 75kg person off the ground, inspired by a video of a similar experiment. The user is experimenting with bottle rockets and seeks advice on the necessary pressure to achieve lift-off, noting that previous attempts with soda bottles raised concerns about stability. They mention that optimal water volume for rockets is about one-third of the bottle's capacity and express interest in avoiding additives for safety reasons. The user is also exploring the possibility of modifying the nozzle shape and size to enhance thrust. Overall, they are looking for calculations and insights on achieving successful lift-off with their setup.
Tristan77
Firstly this is my first post on Physics Forums so hello to everyone.
The question I have came about after experimenting with (soda pop) bottle rockets with my niece and nephew, and a certain video on youtube showing a Japanese guy strapped to a bunch of bottles (I estimate about 21, but it is hard to tell).
There is quite a lot of suspicion on whether this is real or a doctored fake (although if it is fake, what exactly are they trying to guerilla-market here?).
My brother and I have decided to try this but instead of using many soda bottles and the problem this has with theoretical instability due to the combined rocket 'exhaust' being so far away from the persons centre of gravity, we have come up with the plan to use two 19liter 'water cooler style' bottles which would put the twin exhausts only about 8 inches or so away from the spine (behind a alloy backplate for safety). I am doing some experiments with the failure pressure for these bottles before we get started, but the engineering is a bit tricky due to the neck design and I keep blowing out my plugs. I thought I would post here to get everyone's comments and advice before I invest any more time. With about 20psi and using the bottle alone, I can easily fire the thing over 30 feet high.
SO, after that very long intro, here is my question: Will two 19Liter bottles have enough stored energy to lift a 75kg person a few meters off the ground (into a lake)? If so, how much pressure would I need? How high could I conceivably get?
All the bottle rocketeers out there suggest the optimum amount of water is 1/3 the interior volume of your pressure vessel so I would have 12.6L between two bottles. The neck of the bottle is 44mm or 1 3/4" inside diameter.
Some of the above rocketeers use additives to change the viscosity and increase thrust, but I would like to stay away from that due to the fact I will be near (and in) water.
I have life insurance.
I wrap my bottles in fiberglass reinforced tape which would increase their burst pressure significantly.
But take away the possibility of failure of the bottles, what are the pressures required??
If I could change the shape and/or size of the nozzle would that help?
You would want to sit inside the rocket to have the best stability. Have as many liquid water boosters on the side, and a large tube in the middle where you can sit. Use an air compressor to pump up each bottle, and release them all at once. Bam instant renewable resource rocket
Anyone out there got some numbers?
At 0:31, as he launches, his shoulders seem to be pulled forward against the straps, before the rockets fire, rather than being pulled by the straps. More obviously, as people point out on YouTube, his flight path doesn't seem consistent the direction of the jets, all that spinning, etc.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
