Chaos' lil bro Order said:
Thanks Marcus, best response yet!
You are welcome!
There is another calculator besides Wright's that might be useful to you.
http://www.earth.uni.edu/~morgan/ajjar/Cosmology/cosmos.html
You asked a question back in post #7 about something involving z = 1000. This calculator would tell you corresponding speeds and also would tell the light travel time. So I mention z = 1000 as an illustration. But that is a CMB size redshift and the numbers are a bit stupendous. So you might also want to try redshift 1.5 or 2 or 3.
Morgan's calculator has the same basic functions as Ned Wright's -----you put in parameters like 71 for Hubble and 0.27 for matter and 0.73 for dark energy (the famous "73%") and once that is taken care of then you can put in anything for the redshift z and it will tell you the Hubble-law distance
it does NOT have some other features that Wright does, but it does have a couple of features his doesnt. Morgan's will give you the distance, say for redshift z = 1000 (essentially same as Wright's) but it will also give you the PRESENT recession SPEED of the matter that emitted the light that we are now receiving that has redshift 1000.
And also interesting it will give you the speed that the matter had when it emitted the light.In Morgan's simplified terminology "Omega" means matter density Omega
matter. So you type in 0.27----that is a common estimate (27%) comprising ordinary matter plus dark matter. Again in Morgan's terms, "Lambda" means Omega
Lambda-----the dark energy or cosmol. const. part of total.
so to use the calculator you have to type in 0.27 for Omega ("matter density") and 0.73 for Lambda ("cosmological constant") and 71 for the Hubble parameter (71 km/s per Megaparsec). then you are ready.
then if you put in z = 3 or whatever redshift you want to see distance for (or age when the light was emitted, light travel time, or present/past recession speeds)
you should get that...
If you don't want to try it, or prefer to stick with Ned Wright's distance-from-redshift it is OK
my feelings won't be hurt
but just as a check, in case you do try it: you should get that for z =3 the present distance is 21.07 billion LY.
that is where you put in, for "matter density", "cosmological constant", Hubble parameter, and z the numbers 0.27, 0.73, 71, 3
have to go help with supper.
Back now. Basically the calculator gives you a simple hands-on encounter with GENERAL relativity. what the calculator is using is a certain SOLUTION TO THE EINSTEIN EQUATION associated with names like Friedman, Lemaitre, Robertson, Walker. the metric is called the FRW metric (for Friedman-Robertson-Walker).
In the example I suggested you try----with 0.27 + 0.73 = 1-----the spatial slices are FLAT
so the Hubble-law distance that we are talking about is a STRAIGHT LINE DISTANCE. It is the shortest distance between two points barring excursions into the past or the future.
(It is misleading to attribute superluminal recesssion speeds to the Hubble-law distance not being "along geodesics".)
Anyway, if you are at all interested in General Relativity the spatially flat case of the FRW metric is a simple example to play around with and you have the basics of it on Morgan's calculator.
Bear in mind that individual solutions of Gen Rel do not have to have Lorentz symmetry---they don't need to obey Special Rel (except as a local approximation). So in a particular solution of Einstein's Equation like the FRW metric HAS a idea of rest----it makes sense to say a galaxy is sitting still in some space that is receding from another galaxy----and there is an idea of SIMULTANEOUS. Whereas in Special Rel you do NOT have a notion of rest or simultaneity.
some history: Special Rel was 1905. Gen Rel was 1915.
The earlier theory is the one that has no rest, no simultaneity, and no idea of a distance increasing faster than light.
I don't know if anyone here is particularly interested in Gen Rel or this kind of introduction to it. So I will stop and see if there is any response. First one example. The microwave background comes from z=1100. So think about the MATTER that emitted the light that we are now seeing as microwaves. That matter had a certain RECESSION SPEED at the time it emitted the light.
What was the recession speed of the matter that emitted the CMB photons that we are now receiving?
Anybody?
