Can Ultrasound Be Used to Penetrate Through Air and Bone?
  • Context: Undergrad
  • Thread starter Thread starter Sibilo
    Propagation Ultrasound
The discussion revolves around the feasibility of using low-frequency ultrasound (20-40 kHz) to penetrate through air and bone, and later, soil, for the purpose of stimulating plant growth without pesticides. Participants explore the technical challenges and potential applications of ultrasound in these contexts.
  • Some participants suggest that a low-frequency ultrasound beam may not effectively pass through air and bone due to the inverse square law and impedance mismatches, which could scatter energy and disrupt beam focus.
  • Others propose that using a phased array transducer or ellipsoidal reflector could help focus the ultrasound energy onto the target, potentially overcoming some limitations.
  • There is a shift in focus from bone to soil, with participants discussing how ultrasound might stimulate plant roots, raising questions about the acoustic impedance and how to effectively deliver ultrasound energy to the roots.
  • Some participants inquire about the dimensions of the roots and the required stimulation power, suggesting practical considerations for conducting experiments in pots or greenhouses.
  • One participant mentions existing studies on ultrasound's potential to increase plant growth rates, though they express skepticism about its ability to replace pesticides and request references for such claims.
  • Questions are raised regarding the specifics of the ultrasound application, including the frequency stability, direction of sound energy, and the nature of pests that might be affected.
Participants express differing views on the effectiveness of ultrasound in penetrating materials and stimulating plant growth. There is no consensus on the feasibility of using ultrasound as a pesticide alternative or the specific parameters needed for successful application.
The discussion highlights uncertainties regarding the acoustic impedance of soil and the practical challenges of applying ultrasound in agricultural settings. Participants also note the need for further clarification on the experimental design and objectives.
Researchers and practitioners in botany, agriculture, and acoustics may find this discussion relevant, particularly those interested in innovative pest control methods and the application of ultrasound technology in plant growth stimulation.
Sibilo
good morning I have a small problem, so can a low frequency 20 - 40 khz ultrasound beam pass through 60 cm of "air" and then 3 cm of bone? Considering the low frequency of ultrasound in this case it is possible
Probably not.
The inverse square law, and several impedance mismatches, would greatly reduce the power density and scatter the energy. An interference pattern would be set up in the bone, so there would be no focussed beam.
Given enough power, anything is possible, but it will not remain a neat beam unless you start with a phased array transducer, or an ellipsoidal reflector to focus the energy.
Baluncore said:
Probably not.
thanks Baluncore for your answer, the main problem is the acoustic impedance, even at such low frequencies. what are ellipsoidal reflectors and transducer arrays anyway? can they penetrate solids with sufficient power?
Sibilo said:
... What are ellipsoidal reflectors and transducer arrays anyway?
An ellipse has two focal points. You put the transmitter at one focal point, with the bone target at the other. That overcomes the inverse square law and reflects most energy onto the bone.
A transducer array uses many emitters to produce waves, each with a phase that reinforces, where you want the energy to be concentrated.
yes Baluncore, then I need this project for a botany experiment and therefore the solid part is not the bone, but the soil. so if I used two 20 khz ultrasound beams how can the phase coupling overcome the limit, because if I'm not mistaken two 20 khz beams couple and generate an addition wave. Maybe I'm not understanding. basically I want the beam to overcome the solid barrier in this case the ground
That was a very skilful and fast moving of the goal posts.
Overcoming the soil surface barrier is one problem.
It is unlikely the ultrasonic energy will remain well-behaved in a well-structured soil.
Back to the basics ... What must the beam do once it enters the soil?
yes baluncore I didn't understand what you mean by "very skilled movement" however the soil is quite dense, unfortunately in the translation the word "BONE" came out however the ultrasounds must reach the root and stimulate the plants that's all. except that impedance is a big problem
What is the dimension of the roots that must be stimulated?
How much stimulation power do you require?
Why not bury ultrasound transducers among the roots?
Can you do the experiment in a specially shaped flower pot?
You ask a question, and I give you four more.
no baluncore the dimensions of the roots obviously can vary they are not always fixed, furthermore I cannot put the transducer in the ground or near the plant because it would not make the plant grow and the grasses would destroy it. for the power now I need the beam to reach the root and go beyond the ground then later I can adjust it based on the growth of the plant. yes obviously I will do the experiments with small pots or in a greenhouse, but I have to overcome the problem of acoustic impedance
Sibilo said:
no baluncore the dimensions of the roots obviously can vary they are not always fixed, ...
So you are not working on plants as big as trees in a forest.
Are you trying to make plants grow differently, or to image something in the ground?
Are those plants grasses?
Sibilo said:
... yes obviously I will do the experiments with small pots or in a greenhouse, but I have to overcome the problem of acoustic impedance ...
Acoustic impedance can be sorted once we know the shape and size of the plant problem. If the experiment can be done in a pot, then the pot can be shaped to focus the energy where it is needed.
What are you really trying to do?
Why do you need ultrasound in the soil?
no for now I am focusing on small plants with roots that extend over a diameter of 3 or 4 cm, ultrasound is a way to grow plants without pesticides so that they develop their defenses independently. Unfortunately I'm only using the pot now but then I'll have to go to the greenhouse or open field. but if there is a way to overcome the impedance problem I will do my best to overcome it
I know that there are studies that show an increase growth rate with ultrasound (although it's usually in the lab setting, so in the real word it remains to be seen if it works the same), but I have not seen research that show pesticide can be effectively replaced with ultrasound. Do you have any reference for this?
Now I need some time to think about the concept.
Will the frequency sweep or jump between 20 kHz and 40 kHz, or be fixed?
Will sound energy travel from above the plant or from the side?
Will short pulses of sound be sufficient to kill pests, or must it be continuous?
Do you have samples of pests that can be tested?
What are the feared pest species, stage, and size?
Will dogs, snakes and other animals hunt the source of ultrasound?
Will dogs, snakes and other animals hunt the source of o
no baluncore the frequency is always fixed, it does not change either in frequency or in amplitude. the beam will obviously be slightly above the plant a few cm. for animals like snakes there is no problem we have systems against them. furthermore, the parasites you mention are not small animals but in addition to those also bacteria and fungi that infect the plant, with ultrasound you could stimulate the defenses in a natural way. anyway, tell me how long it will take, and also if it were possible I would like to learn too
I attended a conference where this approach was discussed. however, by creecita we mean precisely that, that is, being able to keep the plant alive despite all the bacteria and viruses, it is still an experimental way
I repeat the answer, then the frequency is fixed and also the amplitude, furthermore the beam travels slightly higher than the plant, as far as snakes or mice are concerned there are systems to chase them away. Furthermore, ultrasound is also used to eliminate bacteria and fungi. tell me how long it will take to get the answer because I want to learn too
Can you give a link to the Conference Proceedings? Or was this more of an "Infomercial" type get-together...?
I studied the concept of acoustic impedance and I understood that it depends on the different density of the materials, so if the density is close the attenuation decreases so if we make the passage of the ultrasound in the air before the ground similar to the density of the ground?
Sibilo said:
https://www.aduc.it/articolo/piante+hanno+linguaggio+base+ultrasuoni_30378.php
Ho berkerman this is a link, but tue conference was in my town
Yikes! That looks like nonsense from what little I've translated from Italian...
Plants have an ultrasound-based language
It was already known that plants had incredible senses for communicating with each other and with their environment. They are therefore equipped with photoreceptors to detect light and distinguish different colors in the spectrum of the same light. They are also equipped with the sense of touch: a tree will adapt its growth based on the wind and its intensity. They are also sensitive to smells and sounds. Plants have even been discovered that fluoresce when attacked by a caterpillar! But until now it was thought that plants remained silent beings.
Mistake! Plants emit ultrasound at frequencies between 20 and 100 kHz and detectable up to several meters away. This is the surprising discovery of Itzhak Khait and his colleagues from Tel Aviv University (Israel), whose article has just been published on the bioRxiv platform.
The article mentioned at the end of that paragraph is at least in English: https://www.biorxiv.org/content/10.1101/507590v4 but it also appears to be self-published (not peer-reviewed). Do you know if this pre-print ever made it into a peer-reviewed journal?
I think this concept is still worthy of scientific experiment, though I would not fund it. It would make a good learning exercise.
Do not place a clear reflector around the plant, because that will block the wind and the rain.
You have one point source of ultrasound, and I believe you want to make a cylinder of sound that will enclose the plant with an isotropic level of sound, that penetrates the surface of the soil from above, to about 30 mm depth.
A radiating wave, from a point source, can be converted to a parallel beam by a parabolic reflector. That is the same principal as a satellite receiver dish.
A dish reflector would point downwards from above the plant, with the transducer at the focus, pointing upwards at the dish. The diameter of the dish will keep some rain off the plant, but sunlight and wind will enter from the side.
The reflected wave will arrive at the soil surface as a plane wavefront, so it should penetrate the surface soil evenly. I would not expect the wave to be reflected efficiently from the soil surface, unless it was flat and wet. Energy will be dispersed and lost in an open-structured soil with a rough surface.
The height of the dish above the ground is not critical, it can be raised as the plant grows.
I expect the dish diameter will be about 300 mm, which is 10 wavelengths at 30 kHz ≈ 5° beam sides. The ratio of focal length, to the diameter of the dish, will be determined by the radiation pattern of the ultrasonic transducer selected. The theory is the same as that of microwave dish "illumination".
The transducer specification, and the power level required, have not been specified.
no berkerman that was the site from which they spoke in the conference, but it is not a technology already in use, but still to be tested
Baluncore said:
I think this concept is still worthy of scientific experiment, though I would not fund it. It would make a good learning exercise. Do not place a clear reflector around the plant, because that will block the wind and the rain.
ok baluncore don't worry about rain and wind or other atmospheric agents which I will resolve later or with other techniques for now I'm interested in ultrasound. so if I understood correctly from your answer (unfortunately the translator doesn't help much) with a parabolic reflector I can get what I'm looking for? furthermore, the dimensions of 30 cm in diameter are fine, also because when you then need to focus the beam on small plants, these can reach dimensions of a few cm, so if you have understood correctly this technology is especially useful for small plants
From what little I read, it seemed to be saying that the plants communicate with each other above ground using ultrasound. Can you point to the part that you are asking about, where driving ultrasound into the root system helps to prevent fungal infestations and pests harming the plants? Thanks.
yes berkemann then as I have already told you this technology is still experimental and we take inspiration from that article, in short it is believed that through ultrasound the plant is able to grow and defend itself in a natural way without the aid of pesticides. but in that article this is not explicitly talked about but it was deduced
Well, at PF in the technical forums we require peer-reviewed journal literature to support discussions. If this is all still highly speculative and not published yet, we may need to shut down the thread.
No but in the article it is written that there is an ultrasound effect as communication between plants, but what I want to do is prove that ultrasound can help plants defend themselves, perhaps by communicating with each other. However, it doesn't seem right to close the thread just now that I was reaching a conclusion
the clues are there, we just need to verify in practice and I want to do it
  • · Replies 31 ·
