Can we accurately measure water pressure using DIY water towers?
The discussion revolves around the feasibility of measuring water pressure using DIY water towers constructed from 2-liter and 1-liter bottles. Participants explore various methods for measuring pressure, the principles of hydrostatic pressure, and potential experimental setups suitable for educational purposes.
  • Experimental/applied
  • Some participants propose that water pressure should be the same for identical heights in both types of bottles, assuming they are filled with the same water.
  • There are suggestions for using valve stem gauges, but some participants note that these may require air and may not be sensitive enough for accurate readings.
  • One participant suggests creating an expansion tank with a valve stem to measure how the water column responds to added pressure.
  • Another idea involves using a syringe to measure changes in air volume under pressure as water depth increases.
  • Some participants discuss using the height of a fluid column to measure pressure and propose linking the two bottles to demonstrate pressure equalization.
  • There are mentions of using projectile motion, as per Torricelli's law, to measure pressure based on the distance a water jet travels.
  • Several participants share thoughts on the appropriate gauges for measuring pressure, including garden hose gauges and blood pressure cuffs, noting their sensitivity and range.
  • Discussions include the need for calculations to determine how tall a water column is needed for visible results in experiments.
  • Some participants express uncertainty about the safety and feasibility of certain experimental setups, particularly regarding the materials used for pressure vessels.
Participants express a range of ideas and methods for measuring water pressure, with no clear consensus on the best approach or the accuracy of proposed methods. Disagreements exist regarding the effectiveness of different gauges and experimental setups.
Limitations include the sensitivity of available gauges, the safety of proposed experimental setups, and the need for precise calculations to ensure visibility of results in educational contexts.
This discussion may be useful for educators, students, and hobbyists interested in experimental physics, particularly those looking to explore concepts of pressure and fluid dynamics in a hands-on manner.
Gersty
I'd like to explore water pressure by having students build water towers out of both 2-liter bottles and thinner 1 liter bottles.
1. Assuming they build towers of the same height and fill them with the same type of water, we should see the same water pressure for identical heights within the towers correct?
2. Looking for some ideas on how to read the pressure. Are there gauges available to read the pressure at the bottom of each tower? I read somewhere that 1 psi can be generated with each 2.3 or so feet of water depth. I had initially thought to attach the valve stem of an old inner tube to the bottom of each tower so that pressure could be read using easily available tire pressure gauges, but they don't appear to be sensitive enough.
Science news on Phys.org
I think for the valve stem gauges, you need air. So if you could make a small "air trap" which would expose to pressure, then it might work.
Maybe you could do kind of the reverse. Create a kind of expansion tank, with valve stem on top. Pump up with bicycle pump, and see how the column of water responds.
Interesting. That was sort of another extension of the same unit. I wanted to put a chunk of styrofoam into a water filled vessel and then increase the pressure till the styrofoam deformed/crushed. All to demonstrate the effect of hydrostatic pressure at "crush depth". Still trying to work out how much pressure would be needed to accomplish this and then figure out if it could be done safely, ie: without blowing up the vessel which would need to be glass or plastic so the whole thing is visible.
I'm working to create sort of hands-on components to a museum installation aboard a WW2 submarine that will allow visitors to explore the physics of pressure among other things.
That's awesome. If I think of any other ideas, I'll pass them along.
Also, I have seen water pressure gauges, which can screw onto a fitting like on the exterior water faucet (for a garden hose). I remember my dad used to have one at home. It had a dial and a needle. It would read the pressure when you opened the faucet. I found a couple, online. But now looking at these, I don't know if that will help you. The range on a couple are 0-200 psi. You need about a 33 foot tall column of water for 1 atm (14 psi), which will not move the needle very much.
What about using the height of a fluid column to measure pressure? You could link the 2 liter and 1 liter bottles together with a valve and then open it. The levels will equalize when the pressures are equal (which is for equal heights). It would be more dramatic to use a thinner piece of tubing so that you could show that, say 100 ml of water could balance 4000 ml of water as long as the heights are equal. I definitely recommend checking out Pascal's treatise on fluids: The Equilibrium of Liquids. If you have access to a university library (or library loan) you can find it in The Physical Treatises of Pascal.
I am just thinking out loud here. Maybe something like an expansion tank (possibly clear) with some water in it. Hook in a valve with bicycle air pump to add pressure to the tank. Have some clear tubing for the water to move through, and have it run up, vertically.
Another thing: on the Science Channel show Impossible Engineering, they did one about the new Virginia class submarines. They had made a "mini sub" in an aquarium tank, and would pump air out and into it, to make it submerge and surface. That show has several episodes, which are ship or maritime related, this season.
Here's to thinking out loud:
How about measuring pressure by using the projectile motion of a stream a-la Torricelli's law? Fill both vessels to the same height and measure the distance each jet travels before hitting the ground.
Thanks for all the input so far.
You might be able to make a demo/gauge with a large-size syringe body, to form a graduated volume of air under a piston-type arrangement. Start with the syringe almost full of air at atmospheric pressure and seal the tip. Then lower it down into the column and keep reading off the changing volume of the air in the syringe at each depth. You might need to pre-lube the walls of the syringe to keep stiction from being a problem...
http://image.11st.my/g3/2/9/4/9/7/0/35294970_B_V1.jpg
Great idea! Something that could possibly be done in a classroom setting with a number of kids. Need to do some calculations. How tall of a column of water would be needed to produce results in the syringe that would be visible to students?
Water pressure increases by 1atm for about every 10m of depth...
https://dtmag.com/thelibrary/water-world/
Pressure. ... When a diver enters the water, he need only descend to a depth of 33 feet/10 m in salt water (fsw) before the pressure doubles — 14.7 psi x 2 = 29.4 psi. The pressure experienced at this depth is called 2 atmospheres. The pressure increases by 1 atmosphere (14.7 psi) with every 33 feet/10 m of depth.Dec 2, 1998
Water World | Dive Training Magazine
How about Boyle's Law:
P1V1 = P2V2
P1 = 101.325 kPa (STP)
V1 = 20 mL
V2 = 10 mL
P2 = P1V1 / V2 = 20 mL (101.325 kPa) / 10 mL = 202.65 kPa
As a practical matter, it remains to be seen how much of a water column we can build and whether or not it will be sufficient to depress the plunger in the syringe enough to be measured by the hawk-like eyes of some high school students. (sarcasm)
BTW: the V1 and V2 in the previous example were numbers I generated to do the math as an example. :)
Gersty said:
P1V1 = P2V2
V1 = 20 mL
V2 = 10 mL
So you'll get about 1mL per meter. 2-3 meters worth of water column should give you a visible change, assuming you can lube the inside of the syringe wall with something slippery...
Tire gages go to about 60 psi. You need an inexpensive one that's more sensitive.
Check thrift shops for cast off blood pressure cuffs. The gage on them is 0 to 300 mm of mercury. That's about 1 atmosphere, roughly 4X the sensitivity of an everyday tire gage.
But for more exactly what you asked
try a search on "inches of water pressure gage"
my first hit
I don't know where you are with this project. I was at Academy sporting goods, and purchased this pump with pressure gauge for $6.99, and I was reminded of your project, as the ball that I need to inflate recommends 4 to 6 psi, and this gauge seems to do the trick.
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 32 ·
12K
  • · Replies 39 ·
17K
  • · Replies 20 ·
11K
9K
