Can we see nuclear explosion from orbit?
17 replies · 18K views · last reply
Chitose
As topic says
Can we see Nuclear Explosion form orbit altitued? or even form space?
Just curious.
ideasrule said:
You can see manmade buildings from space. A nuclear explosion is certainly bigger and brighter than any manmade building. We can also see nuclear explosions in space quite easily; see:
http://en.wikipedia.org/wiki/Starfish_Prime
Errr, which buildings exactly? As well you more than likely would not be able to see the actually explosion (as in the visible energy coming out) from space. Our average nuclear bombs aren't really 'that' powerful. You might be able to see just the first few moments of the explosion if you knew where to look and were given good conditions but it wouldn't last too long and would probably just look like a 'bright' point. Space is quite a distance. The average nuclear bomb however would have no problem pushing a mushroom cloud through and over most clouds. The problem is knowing what and where/when to look for it.
Unless the OP means by the aided eye, in which case everything is visible
Assuming by "space" the OP just means low Earth orbit, a nuclear explosion is orders of magnitude larger than what is necessary to see with the unaided eye. From LEO, you can see a large campfire! Or consider it from the other direction: you can see most satellites with the naked eye from the ground. They are much, much dimmer than a nuclear explosion as they are merely reflecting light from the sun. Then, certain satellites with flat, reflective surfaces will "flare", reflecting direct sunlight to a small area on earth. These are spectaclarly bright to the naked eye - much brighter than any star or planet. http://www.satobs.org/iridium.html
I had an Iridium flare happen to me just last week. I was using my finder scope to get set up on M42 and this big flash happened. Scared the poo out of me!
russ_watters said:
You can probably see an airburst nuke on Earth from the Moon.
Funnily enough, I was just thinking the very same thing yesterday, as I was reading about the largest bomb ever made by humans, a 57 megaton hydrogen bomb that the Russians detonated over Novaja Zelmlja in 1961. (LINK)
The average nuclear weapon is far from this size, lol. I think in America they are on average 100-300kT. In Russia they go up to 500kT.
pallidin said:
"Average"? Maybe, but megaton yield is not unusual.
Here's an interesting link: http://nuclearweaponarchive.org/Usa/Weapons/Allbombs.html
I guess I should have said the average active weapon to make it clearer what I was saying. Yes there was a time period where people thought that making powerful weapons was the best and so big weapons exist. Most are not active though, majority are retired and recycled for other weapons.
Something we have to think about with this is that a lot of released visual wavelength energy gets absorbed before leaving the atmosphere. A HANE would definitely be visible but a ground explosion, I'm not sure... it'd probably just be a really quick flash which would be obscured quickly
Chitose said:
As topic says
Just curious.
Absolutely.
It all depends what you are looking with... If you are using your eyes, distance is finite... If you are using an gamma ray/xray telescope pointed in the right spot... you could see one from light years away.
You can easily see lightning from orbit, which it is much less brightness and duration than a nuclear explosion.
Not that much. A nuke is VERY bright, MUCH brighter than you think it is. The flash, fireball, and resulting cloud would very easily be seen from orbit.
I vaguely remember reading somewhere that the only thing you can see from space is the Great Wall of China. However, I don't think this is right because China is on the other side of the earth. Maybe they mean at night. Anyway, here is a website that might help.
A nuclear explosion as seen from space.
