Can We Travel Close to the Speed of Light?
The discussion revolves around the theoretical limits of traveling close to the speed of light, exploring concepts such as the Planck length and its implications for speed and distance. Participants engage with both theoretical and conceptual aspects, questioning the significance of Planck units in the context of speed and acceleration.
  • Some participants propose that while it is impossible to travel at light speed, it is theoretically possible to approach it closely, with discussions about the highest possible speed being just below light speed.
  • There is a debate about the relevance of the Planck length in defining speed, with some arguing that speed cannot be defined in terms of Planck units.
  • One participant suggests that speed cannot change by less than one Planck length per second, prompting further questions about the implications of this idea.
  • Others argue that time and space are not quantized, challenging the notion that there is a smallest unit of distance or that speeds must adhere to Planck units.
  • Some participants highlight the energy requirements for accelerating objects to near light speed, indicating that practical limits exist based on energy input.
  • There is a mention of common misconceptions regarding the Planck length and its significance, with references to external resources for clarification.
  • Participants express uncertainty about whether the Planck length is indeed the smallest unit or if other possibilities exist.
  • Discussions also touch upon the effects of time dilation and length contraction on measurements of speed and distance.
Participants do not reach a consensus on the relevance of the Planck length or the implications of quantized units in relation to speed. Multiple competing views remain regarding the theoretical limits of speed and the significance of Planck units.
Limitations include unresolved assumptions about the significance of Planck units, the dependence on definitions of speed and distance, and the lack of consensus on the implications of time dilation and length contraction.
Mederman
Hello!
My kid asks if this is theoretical idea is correct and I just don't know this stuff very well:
It is impossible to travel at light speed but not impossible to travel just below. So the highest theoretical speed should be:
"The distance light has traveled in one second" minus "One Planck length"
I ask: How about "The distance light has traveled in on hour" minus "One Planck length", isn't that closer to the speed of light?
He didn't like that because he think that a Planck length is the smallest thing and cannot be divided. How should we think about this?
Or how about the distance light traveled in one year minus a Planck length? Or the distance light traveled over 13.8 billion years minus a Planck length, etc ad nauseum...
What exactly is the point in all this?
Zz.
The highest possible speed is the speed of light in a vacuum (c). However, this is only achievable for particles without mass. For everything that has a mass, c can theoretically be approached as close as one has energy to accelerate the mass. But that gets soon in ranges where the total energy of the universe isn't sufficient anymore. So there is a practical limit below c, depending on the mass. The difference between any actual speed and c has nothing to do with the Planck length. The value is c, regardless whether measured in km/h, mph, lightseconds/second, lighthours/hour or whatever. This difference is a difference of speeds, hence measured in the same units. If it is close to c, then it is something like 0.999999999999999991c and the difference will be 1c-0.999999999999999991c=0.000000000000000009c and thus has the same unit as c has. There is no Planck length ansywhere.
Mederman said:
speed should be:
Presumably also divided by one second :wink:
I asked him again what he meant. He says that speed cannot change less than one Planck-length per second.
I think this is the question I should have asked to begin with.
This doesn't make sense. Second is an arbitrary unit. Why should it have any physical relevance? If you say Planck-length per Planck-time you end up exactly with c.
Ok, I'll try this: Can something travel less than one Planck length.
The Planck length and Planck time are irrelevant. It's a common misconception that you have picked up that they have some significance in this respect. Time and space are not quantised like that.
I'll use this answer and tell him that Planck length may be a smallest unit, but distances aren't a fixed number of Planck units and speeds can change less than one Planck length per second.
Thanks for helping me out, you guys are great!
It may. Or the smallest length could be something else. Or there may be no smallest length.
Mederman said:
Summary:: The maximum speed in therory
It might be helpful for your child to understand the energies required to accelerate an object to near light speed. That might help to end the "how super close" type questions. Calculate the energy it takes to accelerate even a small particle close to light speed, and you start to get an appreciation for how hard it is. Even for "theoretical" questions, you cannot exceed reasonable amounts of energy input.
Well, it's even worse: due to time dilation and length contraction the chosen units/intervals won't necessarily be consistent with each other for different observers, or the same observer at different points in a trip.
This is sort of fixable, but of course there is always cost. For now I would say it's an idea that lacks both experimental evidence and theoretical motivation.
  • · Replies 26 ·
  • · Replies 53 ·
