MHB Simplex Method for Linear Programming Problems: Limitations and Exceptions
  • Thread starter Thread starter evinda
    Method
The discussion centers on the application of the simplex method to a specific linear programming problem, highlighting the challenges posed by degenerate solutions. Participants debate whether a basic feasible non-degenerate solution is necessary to use the simplex method, concluding that while a degenerate solution can be utilized, it complicates the process. They discuss the construction of initial tableaux and the selection of pivot elements, emphasizing the need for careful consideration to avoid errors. The conversation also touches on the criteria for determining optimality and the potential for better solutions despite encountering degeneracy. Ultimately, the group acknowledges the complexities of working with degenerate solutions in linear programming.
evinda
MHB
If we have a linear programming problem that is of the form as the following:
$$\max (- x_1+ 2 x_2-3x_3) \\ x_1- \frac{1}{2} x_2+x_3+x_{4}=11 \\ 2x_2-x_3+x_5=0 \\ 2x_4+x_6=8 \\ x_i \geq 0, i \in \{ 1, \dots, 6 \}$$
we cannot use the simplex method since we cannot find a basic feasible non-degenerate solution , right?
Re: Optimal solution
$$\max (- x_1+ 2 x_2-3x_3) \\ x_1- \frac{1}{2} x_2+x_3+x_{4}=11 \\ 2x_2-x_3+x_5=0 \\ 2x_4x_6=8 \\ x_i \geq 0, i \in \{ 1, \dots, 6 \}$$
Hey evinda! (Smile)
I think we can still use the simplex method.
A degenerate basic feasible solution does not prohibit that - it's just something to be careful with. (Nerd)
I like Serena said:
Hey evinda! (Smile)
So we pick $(11,0,0,0,0,8)$ as the initial solution? (Thinking)
- - - Updated - - -
But then don't we have just two basic variables? Or am I wrong? (Thinking)
I think that's not a solution. (Shake)
Can you make an initial tableau? (Wondering)
$\begin{bmatrix}
B & b & P_1 & P_2 & P_3 & P_4 & P_5 & P_6 & \theta\\
P_1 & 11 & 1 & -\frac{1}{2} & 1 & 1 & 0 & 0 & \\
P_5 & 0 & 0 & 2 & -1 & 0 & 1 & 0 & \\
P_6 & 8 & 0 & 0 & 0 & 2 & 0 & 1 & \\
& z & 1 & -2 & 3 & 0 & 0 &0 &
\end{bmatrix}$
Right?
Is there a typo in the 3rd equation? (Wondering)
Oh yes, I am sorry...
It should be $2x_4+x_6=8$... (Blush)
Then that initial solution is fine.
And we will still have 3 basic variables.
They correspond to the columns with a single non-zero entry. (Mmm)
Then we get this:
$\begin{matrix}
B & b & P_1 & P_2 & P_3 & P_4 & P_5 & P_6 & \theta & \\
P_1 & 11 & 1 & 0 & \frac{3}{4} & 1 & \frac{1}{4} & 0 & &L_1'=L_1+ \frac{1}{2}L_2' \\
P_2 & 0 & 0 & 1 & -\frac{1}{2} & 0 & \frac{1}{2} & 0 & & L_2'=\frac{L_2}{2}\\
P_6 & 8 & 0 & 0 & 0 & 2 & 0 & 1 & &L_3'=L_3 \\
& z & 1 & 0 & 2 & 0 & 1 &0 & & L_4'=L_4+2L_2'
\end{matrix}$
Do we accept this tableau, although it gives again a degenerate basic feasible solution? (Thinking)
If so, then it gives the optimal solution, right?
That's the problem with a degenerate condition - we can't be sure yet.
So there may still be a better solution.
We have to keep trying. (Thinking)
So we apply the simplex method till what criterion is satisfied? (Thinking)
Until it's not degenerate and it's optimal, or until we cannot find a more optimal solution. (Nerd)
A ok... In this case, do we choose any of $P_3, P_4,P_5$ to get in the basis or do we take into consideration an other criterion? (Thinking)
Which one will get us out of the degenerate condition? (Wondering)
Both $P_3$ and $P_5$, right? (Thinking)
I chose $P_3$ and I got the following tableau:$\begin{matrix}
B & b & P_1 & P_2 & P_3 & P_4 & P_5 & P_6 & & \theta\\
P_3 & \frac{44}{3} & \frac{4}{3} & 0 & 1 & \frac{4}{3} & \frac{1}{3} & 0 & 11 &L_1''=\frac{L_1' 4}{3} \\
P_2 & \frac{22}{3} & \frac{2}{3} & 1 & 0 & \frac{2}{3} & \frac{2}{3} & 0 & 11 & L_2''=L_2'+\frac{1}{2}L_1''\\
P_6 & 8 & 0 & 0 & 0 & 2 & 0 & 1 & 4 &L_3''=L_3' \\
&z & -\frac{5}{3} & 0 & 0 & -\frac{8}{3} & \frac{1}{3} & 0 & & L_4''=L_4'-2L_1''
\end{matrix}$
$-\frac{5}{3}>-\frac{8}{3}$, thus $P_4$ gets in the basis and $P_6$ gets out of the basis.
Then I got the following tableau:
$\begin{matrix}
P_3 & \frac{28}{3} & \frac{4}{3} & 0 & 1 & 0 & \frac{1}{3} & -\frac{2}{4} & \frac{28}{4} &L_1'''=L_1''-\frac{4}{3}L_3'' \\
P_2 & \frac{14}{3} & 0 & 1 & 0 & 0 & \frac{2}{3} & -\frac{1}{3} & - & L_2'''=L_2''-\frac{2}{3}L_3'''\\
P_4 & 4 & 0 & 0 & 0 & 1 & 0 & \frac{1}{2} & - &L_3'''=\frac{L_3''}{2} \\
&z & -\frac{5}{3} & 0 & 0 & 0 & \frac{1}{3} & \frac{4}{3} & & L_4'''=L_4''+\frac{8}{3}L_3'''
\end{matrix}$
Then $P_1$ gets in the basis and $P_3$ gets out of the basis:
$\begin{matrix}
P_1 & \frac{28}{4} & 1 & 0 & \frac{3}{4} & 0 & \frac{1}{4} & -\frac{1}{2} & &L_1''''=\frac{L_1''' 3}{4} \\
P_2 & \frac{14}{3} & 0 & 1 & 0 & 0 & \frac{2}{3} & -\frac{1}{3} & & L_2''''=L_2'''\\
P_4 & 4 & 0 & 0 & 0 & 1 & 0 & \frac{1}{2} & - &L_3''''=L_3''' \\
&z & 0 & 0 & \frac{5}{4} & 0 & \frac{3}{4} & \frac{3}{4} & & L_4''''=L_4'''+\frac{5}{3}L_1''''
\end{matrix}$
Is everything right? (Thinking)
If so, do we deduce now from the fact that $z_k''''-c_k \geq 0 \forall k$ and that we have a non-degenerate basic feasible solution, that it is the optimal one? (Thinking)
We had the initial tableau:
evinda said:
$\begin{bmatrix}
\end{bmatrix}$
Then we picked the initial solution $(11,0,0,0,0,8)$ and got this:
evinda said:
Then we get this:
$\begin{matrix}
\end{matrix}$
I think there is a mistake in that tableau. (Worried)
Shouldn't it be:
\begin{array}{cc|cccccc}
B & b & P_1 & P_2 & P_3 & P_4 & P_5 & P_6 \\
\hline
P_1 & 11 & 1 & & \frac{1}{2} & 1 & \frac{1}{2} & \\
P_2 & 0 & & 1 & -\frac{1}{2} & & \frac{1}{2} & \\
P_6 & 8 & & & & 2 & & 1 \\
\hline
& & 1 & & 2 & & 1 &
\end{array}
(Wondering)
I like Serena said:
We had the initial tableau:Then we picked the initial solution $(11,0,0,0,0,8)$ and got this:
Shouldn't it be:
\hline
\hline
& & 1 & & 2 & & 1 &
\end{array}
(Wondering)
I retried it and I got again the same result... (Worried)
Isn't it $L_1'=L_1+ \frac{1}{2} L_2'$ ?
At the first row and third column we have the number $1$.
And then $1+ \frac{1}{2} \left( - \frac{1}{2} \right)=1- \frac{1}{4}=\frac{4-1}{4}=\frac{3}{4}$
If so, then the optimal solution is $\frac{7}{3}$, right? (Thinking)
The optimal solution has an objective value of $-7$.
Currently you're at $-11$.
To get there, we need $P_4$ in the basis.
How did you find that the optimal solution has an objective value of $-7$? (Thinking)
There should be a mistake at one of my tableaus. But I always find the same ones... (Sweating)
Do you have an idea what might be wrong?
Let's start from the beginning. (Sweating)
We have the initial tableau:
\begin{array}{cc|ccccc}
B &b &P1 &P2 &P3 &P4 &P5 &P6 \\
\hline
P1 &11 &1 &-0.5 &1 &1 & & \\
P5 &0 & &\enclose{circle}{2} &-1 & &1 & \\
P6 &8 & & & &2 & &1 \\
\hline
& &1 &-2 &3 & & & \\
\end{array}
With corresponding solution $(11, 0, 0, 0, 0, 8)$ and objective value $z=-x_1+2x_2-3x_3=-11$.
After selecting the circled $\enclose{circle}2$ we get:
\hline
P1 &11 &1 &0 &0.75 &1 &0.25 &0 \\
P2 &0 &0 &1 &\enclose{circle}{-0.5} &0 &0.5 &0 \\
P6 &8 &0 &0 &0 &2 &0 &1 \\
\hline
&0 &1 &0 &2 &0 &1 &0 \\
\end{array}
With corresponding solution $(11, 0, 0, 0, 0, 8)$ and objective value $z=-11$.
I think you also had this. (Thinking)
I believe you then selected $P_3$, in which case I'm getting:
\hline
P1 &11 &1 &1.5 &0 &1 &1 &0 \\
P3 &0 &0 &-2 &1 &0 &-1 &0 \\
\hline
&0 &1 &4 &0 &0 &3 &0 \\
\end{array}
But this looks different from what you have... :confused:
\hline
\hline
\end{array}
\hline
\hline
\end{array}
\hline
\hline
\end{array}
Before we put $P_3$ in the basis we see that the pivot is $\frac{3}{4}$, so we have to multiply the first line by $\frac{4}{3}$, don't we? (Thinking)
I picked the pivot $\enclose{circle}{-\frac 12}$. Doesn't that one have a lower $\theta$ value? (Wondering)
I didn't pick it since $\theta$ is defined as follows:
$$\theta= \min_i \left \{ \frac{x_{i0}}{x_{ij}}: x_{ij}>0\right \}>0$$
(Thinking)
(Thinking)
Simplex algorithms vary. What is your algorithm exactly?
Which column should we select?
And does it take degenerate tableaux into account? (Wondering)
$(\overline{x_0})$ is a basic non-degenerate feasible solution
Step 1: We create a $(m+1) \times (n+4)$ matrix as follows:
  • At the first column we write the basic columns $P_1, \dots, P_m$
  • At the second column we write the values of the corresponding cost factor.
  • At the third column we write the initial basic non-degenerate feasible solution $\overline{x_0}$.
  • At the next n columns we write the elements of the columns of the matrix $A$.
  • The last column remains currently empty.
  • At the last row we write the value $z_0$ of the objective function that corresponds to the solution $\overline{x_0}$, and also the values of the differences $z_k-c_k, k=1, \dots, n$.
Step 2: We check if $\overline{x_0}$ is optimal by checking the differences $z_k-c_k, k=m+1, \dots, n$.
  • If $z_k-c_k \geq 0 \forall k=m+1, \dots, n$ then $\overline{x_0}$ is an optimal solution.
  • If $z_j-c_j<0$ for some $j \in \{ m+1, \dots, n \}$ then $\overline{x_0}$ is not an optimal solution.
Step 3: How do I choose the new column $P_j$ that gets into the basis ( of $\mathbb{R}^m$)
The column that will get basic is given by the following relation:
$P_j$ such that $|z_j-c_j|= \max_k \{ |z_k-c_k|: z_k-c_k<0\}$
Step 4: How do I choose the column $P_i$ that gets out of the initial basis $B=P_1, \dots, P_m)$
$P_i$ such that $\frac{x_{i0}}{x_{ij}}= \min \{ \frac{x_{k0}}{x_{kj}}: x_{kj}>0\}$Step 5: We compute thecoefficients of the next tableau from the relations:
$$x_{ik}'=\frac{x_{ik}}{x_{ij}} , k=0,1, \dots, n \\ x_{sk}'=x_{sk}-\frac{x_{ik}}{x_{ij}} x_{sj}, s=1,2, \dots, m, m+1, s \neq i, k=0,1,2, \dots, n \\ x_{(m+1)k}=z_k-c_k, k=1, \dots, n \\ x_{(m+1)0}=z_0$$
$$\Gamma_i'=\frac{1}{x_{ij}} \Gamma_i \\ \Gamma_m'=\Gamma_m- x_{mj} \Gamma_i'$$
Indeed. It does not take a degenerate tableau into account.
It considers a situation where $z_k−c_k=0$ as an optimal solution.
But that is not necessarily the case when one of the $b$ values is $0$.
In such a case we need an extension to the algorithm to find the actual optimal solution.
Does your course material mention what to do when we have a degenerate basic feasible solution? (Wondering)
I found this now in my textbook:
Degenerate solutions:
  • Obviously if $\theta_0=\min_i \left\{ \frac{x_{i0}}{x_{ij}}: x_{ij}>0\right\}$ is achieved in more than one rows ( for example $\theta_0=\frac{x_{10}}{x_{1j}}=\frac{x_{20}}{x_{2j}}$), then the corresponding solution $x_1$ is degenerate.
  • If the initial solution is degenerate , then we might have had $x_{10}=0, x_{1j}>0$, thus $\theta_0=0$ and therefore $x_1=x_0$ and $z_1=z_0$, i.e. that the solution couldn't be improved.At both of the above cases, we turn the degenerate solution to non-degenerate, replacing $0$ of the basic variable by $\epsilon>0$, arbitrarily small and we continue normally till we find the optimal solution, and then we set again $\epsilon=0$.
If we do this, will we get a different tableau? (Thinking)
The last tableau that we get is the following, right?
$\begin{matrix}
B & c_B & b & P_1 & P_2 & P_3 & P_4 & P_5 & P_6 & \theta & \\
P_1 & -1& 7 & 1 & 0 & \frac{3}{4} & 0 & \frac{1}{4} & -\frac{1}{2} & & L_1''''=L_1''' \frac{3}{4}\\
P_2 & 2 & 0 & 0 & 1 & -\frac{1}{2} & 0 & \frac{1}{2} & 0 & & L_2''''=L_2'''-\frac{2}{3}L_1''''\\
P_4 & 0 & 4 & 0 & 0 & 0 &1 & 0 & \frac{1}{2} & & L_3''''=L_3'''\\
& z & -7 & 0 & 0 & \frac{5}{4} & 0 & \frac{3}{4} & \frac{1}{2} & & L_4''''=L_4'''+\frac{5}{3}L_1''''
\end{matrix}$If we replace $0$ of the basic variable by $\epsilon$ and then set $\epsilon=0$ at the last tableau to find the solution, don't we get the same tableau? (Thinking)
