TCS
- 84
- 1
If you are in free fall inside a black hole, shouldn't it feel like normal space even though people on Earth saw you enter a black hole?
TCS said:If you are in free fall inside a black hole, shouldn't it feel like normal space even though people on Earth saw you enter a black hole?
Actually, an observer outside the event horizon will never see anyone pass through the horizon. They will see them approach the horizon, but slow down and come almost to a stop (and the light red-shifted to almost zero frequency).dx said:They not only saw you enter the black hole, they also saw you get thermalized by the horizon! Yet the infalling observer notices nothing special at the horizon.
DrGreg said:Actually, an observer outside the event horizon will never see anyone pass through the horizon. They will see them approach the horizon, but slow down and come almost to a stop
dx said:Yes that's what I meant. To an observer outside, the infalling observer appears to asymptotically approach the horizon. This is in classical general relativity. When we take quantum mechanics into account, the picture changes a little bit: when the infalling observer is very close to the horizon, around the order of the plank length, the outside observer would see the infalling observer thermalized and re-emitted as Hawking radiation.
Finbar said:I never really got why the in falling observer has to fall through the horizon. If the horizon is dynamical surely it can just reseed as the black hole evaporates.
Dmitry67 said:Because there are different types of horizon: apparent and absolute.
Observer can fall thru the absolute horizon (at shw. radius) but he has his personal, apparent horizon, which receded in from of him when he approach the black hole.
Regarding the evaporation, the infalling observer falls down very quickly, much faster than absolute horizon evaporates, so of course if crosses it before it evaporates. How it is visible from the outside is a different story.
It only takes an infinite time for the outside observer to see the infalling one reach the horizon in the case of an eternal black hole, in the case of an evaporating black hole the light from the crossing would reach the outside observer at the exact same moment he sees the black hole evaporate completely--see the "What about Hawking radiation?" question here:Finbar said:But I don't understand how the in falling observer crosses the event horizon quicker than the black hole evaporates? This makes no sense to me. It takes an infinite time(measured by the outside observer) for the in falling observer to cross the event horizon but only a finite time for the black hole to evaporate
Also note that even in the case of an eternal black hole, it's a little ambiguous to say that the outside observer "measures" an infinite time for the infalling observer to cross the horizon--it's true that it takes an infinite time for the outside observer to receive a signal from this event, but the outside observer can still use a coordinate system (like Kruskal-Szekeres coordinates) where it only takes a finite coordinate time to reach the horizon.But I just said that an outside observer would never observe an object actually entering the horizon! If I jump in, will you see the black hole evaporate out from under me, leaving me intact but marooned in the very distant future from gravitational time dilation?
You won't, and the reason is that the discussion above only applies to a black hole that is not shrinking to nil from evaporation. Remember that the apparent slowing of my fall is due to the paths of outgoing light rays near the event horizon. If the black hole does evaporate, the delay in escaping light caused by proximity to the event horizon can only last as long as the event horizon does! Consider your external view of me as I fall in.
If the black hole is eternal, events happening to me (by my watch) closer and closer to the time I fall through happen divergingly later according to you (supposing that your vision is somehow not limited by the discreteness of photons, or the redshift).
If the black hole is mortal, you'll instead see those events happen closer and closer to the time the black hole evaporates. Extrapolating, you would calculate my time of passage through the event horizon as the exact moment the hole disappears! (Of course, even if you could see me, the image would be drowned out by all the radiation from the evaporating hole.) I won't experience that cataclysm myself, though; I'll be through the horizon, leaving only my light behind. As far as I'm concerned, my grisly fate is unaffected by the evaporation.
All of this assumes you can see me at all, of course. In practice the time of the last photon would have long been past. Besides, there's the brilliant background of Hawking radiation to see through as the hole shrinks to nothing.
That logic would be correct under Newtonian gravity, but under general relativity it isn't. In fact, for a static non-rotating black hole, there are no stable orbits below a radius of 1½ times the event horizon. See photon sphere.Trenton said:The short answer must be yes you can be in a stable orbit inside the event horizon. The horizon is only the radius at which the escape velocity is light. The velocity required for orbit is lower than this and is thus legal. The raduis at which one travel at the speed of light in a circular orbit is quite a bit less than that of the horizon. It would also be possible to describe an eliptical orbit that was part inside and part outside the horizon.
Finbar said:But even so he will not reach the singularity until the black hole evaporates. He still remains in the proximity of the event horizon until the end.
Dmitry67 said:Ok, let's define what do you mean first. Do you understand that in GR there are 3 *dfferent* things which can be described by what you had said:
1. In the frame of freely falling observer
2. For an observer in infinity, based on his/her calculations
3. For an observer in infinity, based on the image of light he/she receives
For 2, you should also specify type of coordinates
Do you undertsand that these 3 approaches give DIFFERENT result?
It is important to understand that there is no clear meaning of "remains in the proximity" until you specify method - 1, 2 or 3.
Finbar said:Then let's say we have some matter that crosses the apparent horizon at some time t.
Dmitry67 said:I am losing you here
1. what apparent horizon
A. apparent horizon of an infalling observer? he never crosses it as it always recedes in front of his as he progresses inside the BH
B. When falling observer crosses Schwarzschild radius (based on his calculations, as he does not feel anything strange when it happens)
C. or something different from perspective of observer at infinity?
2. some time - in what metrics? How 'some time t1' for falling observer is mapped to 'some time t2' for an observer at infinity?
Dmitry67 said:if t is the proper time of the observer at infinity - ok
now you should chose the coordinates which are not singular at Schwarzschild radius.
I like Eddington–Finkelstein coordinates, for example:
[PLAIN]http://www.valdostamuseum.org/hamsmith/DFblackIn.gif[/QUOTE]
Yeah that's what I use in practice. Ok so you know the Vaidya metric for an evaporating black hole? I'm basically talking about the causal structure of that metric in Eddington–Finkelstein coordinates. So just the schwarzschild metric in Eddington–Finkelstein coordinates with M->M(t) where t is the "advanced time". In this case the apparent horizon is just R=2GM(t). M(t) is found via the stephan Boltzmann law for the hawking radiation.
So then what I say is I can't get a photon that starts at r>2GM(t) to get to r=0 before M ->0.
Dmitry67 said:I tried to draw it (sorry for the quality)
Black - shrinking BH
red - falling observer
green - hawking radiation
Yes, a major experiment is currently underway. Gravity Probe B is currently in orbit measuring the frame dragging effect around earth.Trenton said:It is said that a rotating singularity 'drags' spacetime around with it. If this were the case any rotating body such as the Earth or the Sun would do the same - and even though the effects would be orders of magnitude smaller, this could be measured. Has it been?
