Evil Bunny
- 241
- 0
Can you create an arc in a vaccum?
The discussion revolves around the possibility of creating an electric arc in a vacuum, exploring the conditions necessary for such an event, and the nature of arcs compared to other forms of electron flow. Participants examine the differences between arcs in a vacuum versus in the presence of gas and the implications of ionization.
Participants express a range of views on whether an arc can be created in a vacuum, with no consensus reached. Some agree that conditions such as voltage and the presence of ionization sources are critical, while others challenge the definitions and conditions under which an arc can occur.
Participants highlight the complexity of achieving a perfect vacuum and the challenges in experimentally demonstrating arcing in such conditions. There are also discussions about the definitions of arcs versus other forms of electron flow, which remain unresolved.
Evil Bunny said:Can you create an arc in a vaccum?
KavinMassey said:Can someone tell me an electric arc is visible in a vacuum or not?
_______________
Moving to Australia
yungman said:This is a good question. You really don't get a perfect vacuum. I worked with HV in high vacuum, we do have arc, but mostly are from creepage on the surface of insulator. But I am not sure you arc through vacuum. This is very different from emission of electrons, arcing is an avalanche of electrons, not just an emission. The instantaneous current is in hundreds of amps.
nsaspook said:If the voltage is increased to the point the field emission electrons striking other atoms causes secondary electron emission you then form a electron cloud that can cause an avalanche of electrons (arc). On our machines (Semiconductor Ion Implanter acceleration chambers) this radiation is usually in the X-ray range with visible light from the ionization of materials from the electrodes and walls.
http://en.wikipedia.org/wiki/Secondary_emission
http://en.wikipedia.org/wiki/Electron-Cloud_Effect
sophiecentaur said:So that's an answer. If there are no gas atoms in the way then no avalanche can occur and so, by definition, you can't have an 'arc'. It's just a beam of charges on the move.
Evil Bunny said:Does the arc look any different than it would in our normal atmosphere? Same orange-ish color and everything?
Or not - depending on whether an 'arc' is defined by the occurrence of avalanche.Evil Bunny said:So... the consensus is that you can still have a visible arc in a vaccum.
