gracie
- 3
Please help, I've put this is true on my personal statement, but I'm now fairly sure that it is not, but a more expert opinion would be extremely helpful.
The discussion confirms that the SUVAT equations can be derived using Lagrangian mechanics, specifically through the application of the Euler-Lagrange equation. The Lagrangian is expressed as $$L={1\over 2}m({\dot x}^2+{\dot y}^2)-mgy$$, where the derivatives of position with respect to time are crucial for accurate results. Participants emphasize that while deriving SUVAT equations using Lagrangian mechanics is valid, it may not be the most efficient approach. The acronym SUVAT stands for the parameters involved in motion: distance, initial velocity, final velocity, acceleration, and time.
PREREQUISITESStudents of physics, educators teaching mechanics, and anyone interested in advanced kinematics and the application of Lagrangian mechanics in problem-solving.
You are absolutely right, and it is embarrassing to know that I forgot to add the dots! As I punishment, I've written out the full procedures for Gracie.nasu said:The first term in that Lagrangian should have the derivatives of x and y in respect to time.
What about the opportunity for gacie to discover this for herself ? "Give it a try and PF will help you further..." Then it woudn't have been a waste either !Rescy said:Of course! Lagrangian is equivalent to Newton's second law of motion in Cartesian coordinates.
$$L= {1\over 2}m(x^2+y^2)-mgy$$ apply Euler-Lagrange equation for x and y and you derive a differential equation whose solutions are SUVAT.
It is a waste for Lagrangian Mechanics to be applied on SUVAT!
May I ask if you are applying to UK or US?gracie said:Thank you so much everybody, I thought I knew the answer but wanted proof from experts, I really appreciate it :)
BvU said:Hello Gracie, welcome to PF!
Impressed you should be concerned with Lagrangians at 17 !
But, to answer your question: yes you can. Simply write down the Lagrangian and then the Lagrange equations of motion follow.
Rescy said:May I ask if you are applying to UK or US?
And how can one derive distance, initial velocity and time, knowing only the lagrangian?BvU said:Google to the rescue:
s = distance (metres, m)
u = initial velocity (metres per second, ms^-1)
v = final velocity (metres per second, ms^-1)
a = acceleration (metres per second squared, ms^-2)
t = time (seconds, s)
