Is it safe to drink ethanol fuel?
In summary, the conversation discussed the possibility of drinking grain alcohol, which is essentially ethanol, without any additives. However, it was mentioned that producers may add kerosene or other toxic agents to prevent people from consuming it as an alcoholic beverage. It was also noted that fuel and industrial use ethanol is typically "denatured" with toxic agents, while pure ethanol can be purchased in the form of Everclear.
Coin
566
What would happen if you tried?
I mean, I assume by default and in reasonable quantities you can, since grain alcohol is basically just ethanol, right? But do they put any additives in the stuff used for fuel, say? (Let us of course assume this is not ethanol/gasoline mix.)
(This somewhat dumb question was prompted by a discussion elsewhere about a deleted scene from Jackie Chan's Legend of Drunken Master, in which Chan apparently suffers permanent brain damage from drinking industrial-strength alcohol.)
I have heard (but cannot back up) that producers add a certain amount of kerosene to the mix because otherwise people can and do drink the stuff.
If its pure ethanol, yeah sure its basically just moonshine. However, the stuff that you would regularly buy you can't because its not pure ethanol.
You can buy Everclear, which is 95% alcohol. However, if the alcohol is intended for use as fuel, they generally add some amount of a toxic agent (such as methanol), so that it isn't taxed as an alcoholic beverage.
yup, fuel and industrial use ethanol is "denatured". if you want the cheap untaxed stuff, you'll have to make your own. after checking your local laws, of course.
1. Can drinking ethanol fuel make you drunk?
Yes, drinking ethanol fuel can make you drunk. Ethanol is a type of alcohol, and like other alcohols, it can cause intoxication when consumed in large quantities.
2. Is drinking ethanol fuel harmful to your health?
Yes, drinking ethanol fuel can be harmful to your health. Ethanol is a toxic substance and can cause damage to your liver, nervous system, and other organs if consumed in large amounts.
3. Can drinking ethanol fuel be fatal?
Yes, drinking ethanol fuel can be fatal. Consuming large amounts of ethanol can lead to alcohol poisoning, which can result in death.
4. What happens if you accidentally ingest ethanol fuel?
If you accidentally ingest ethanol fuel, seek medical attention immediately. Ethanol can cause irritation and damage to the digestive system and other organs.
5. Is there any safe amount of ethanol fuel that can be consumed?
No, there is no safe amount of ethanol fuel that can be consumed. Ethanol is not meant for human consumption and can cause harm even in small quantities.
  • Earth Sciences
