Can you identify these minerals?
  • Thread starter z.js
    Minerals
What is your favourite kind of mineral?
  • Sulphides
    Votes: 0 0.0%
  • Tellurides
    Votes: 0 0.0%
  • Arsenides
    Votes: 0 0.0%
  • Hydroxides
    Votes: 0 0.0%
  • Nitrates
    Votes: 0 0.0%
  • Sulfates
    Votes: 0 0.0%
  • Molybdates
    Votes: 0 0.0%
  • Phosphates
    Votes: 0 0.0%
  • Arsenates
    Votes: 0 0.0%
  • Total voters
24 replies · 7K views · last reply
z.js
Can you help me identify this mineral and rock? I can't.
I think the mineral is quartz.
I tried the UV light, but it didn't work.
(Mebbe it's something precious!) :eek:
  • Close-up photo of a dark, rough rock specimen on a white background, its surface covered with small pale grey crystalline bumps and sparkling tan grains.
I doubt we can tell exactly from the picture.
What do you mean by "UV light ... didn't work"?
How did you employ the UV light?
What were you expecting?
What happened?
It looks like quartz or agate embedded in something igneous... but really just some white stuff in some grey stuff.
Have you shown it to a geologist? A local rockhound?
I need more information.
At first glance, this slightly blurry photo suggests your rock is a piece of tar filled with fine gravel.
How hard is this sample? (Can you scratch it with a knife?, with your finger nail?, etc.)
How dense is it? Does it feel like it might be metal?
Does it respond to a magnet?
black rock
Hi, I think at first sight the black rock can to be magmatic rock, very hard (isn't?). Quartz, right! And perahps a metal meet. At see later and good chance!
It looks like tar and gravel to me.
What happened?
I expect the OP was checking for fluorescence and phosphorescence of certain minerals.
http://www.galleries.com/Fluorescent_Minerals
The picture looks like some nest cleaning aggomeration from some burrowing animal of years gone past. Difficult to tell from the fuzzy picture.
Probably - still, nice not to have to guess and I like to encourage more scientific reporting in scientific sites ;)
That hadn't occurred to me...
I think the bottom line is that there is not enough data.
Short answer: "no".
I have a lot of information about rocks :approve:(whether they're minerals or not) because I have played with them :biggrin: and even swallowed a lot of them when I was small.
At what place did you find it? A hillock? Roadside? Riverside?
It was found at a rocky beach which was also a fossil site. (Flat Rocks, Inverloch, Australia)
Did you check for the three things prescribed by daqddyo1?
After that heat a 'piece' of the 'bottom' part of the stone (bottom in the picture, a thick black layer) on your stove without allowing the flames to lick it. Does it melt?
The black stuff at the bottom scratched metal. It has a density of about 2.8 g/cm3, and it is not attracted by a magnet. I will see if it melts when I heat it. How hot is a normal alcohol burner?
Hot enough to know if it makes a good rock or not!:biggrin: Anyway let's see if it melts.
There are many metals - lead, tin, copper, iron, steel.
You need the hardness of the rock based on a scale to properly identify.
http://en.wikipedia.org/wiki/Mohs_scale_of_mineral_hardness
please make a sharper shot? It can also be some other sedimentary matirx than tar and gravel
The black stuff scratched a steel knife.
Then don't go to heat it.
I did...:biggrin: The black stuff that the mineral was stuck in seems to be tar. The black rock at the bottom didn't.
You mean it didn't melt? If it were really a mineral, but I don't think it is a mineral very precious. You can do the flame test in your alcohol burner. But that would not give interesting results.
You have a wide (very much) range to match with what you have got. But I don't go for metals.
I was asking about the little things that looked like quartz, not the black stuff.
Is it inside? I thought it looked like quartz-the little white crystals. :confused: :rolleyes:
But yes, that picture does look nice! (how do you do it with a microscope I wonder?:rolleyes:)
  • Dark grey rock sample on a white background with red hand-drawn circles marking pale grey and white granular bumps on its surface, with arrows and the words 'Here' and 'Not here' and question marks annotating the markings.
