Can You Safely Use a Center Tapped Transformer for a Dual Polarity Power Supply?
The discussion revolves around the use of a center-tapped transformer for a dual polarity power supply in a solar system project. The original concern was about measuring the 120V line while ensuring the negative supply remains functional, with fears that shorting the center tap could eliminate the negative voltage. It was clarified that the transformer provides isolation between the primary and secondary, allowing for safe operation if proper precautions are taken. However, caution was advised regarding safety, particularly ensuring that connections remain secure to avoid dangerous situations. Ultimately, while the initial concerns were addressed, the importance of adhering to safety standards was emphasized.
gargeug
I'm designing a set of voltage and current sensors for use with a solar system. I have developed all of the circuits, but it requires both positive and negative voltage supplies. I want to use the classic design using a center tapped transformer with two regulators. But I'm not sure what will happen when I try to measure the original 120V line that is supplying the transformer. I think that it will eliminate the bottom half of the transformer, since the center tap will be at the same potential as the source common, and thus wipe out my negative supply. Am I reading this situation right? If so, is there a way around this problem?
just use a single positive supply and then get one of these: http://pdfserv.maxim-ic.com/en/ds/ICL7660-MAX1044.pdf
It will convert a positive voltage to a negative voltage.
The transformer should isolate the primary from the secondary winding so what is the problem? You should however be careful about safety when measuring primary side voltages. I would look into small instrumentation transformers to get a bit of added protection/isolation when measuring the primary side. Leright may have something if you are not concerned about cost and if the current required from the negative supply is not high. However, it has nothing to do with the ability to measure the voltage on the primary side of the power transformer.
I didn't really specify very good now that I read it. The sensors that I am using to measure the original line voltage are going to be powered from this dual polarity supply I am creating. It is essentially a loop, in terms of block diagrams. Maybe I am not understanding transformers thoroughly. When you say it is isolated, can I imagine it as a source in itself, completely separate from the primary, and thus when I short the primary common to the secondary center tap, there will be no conflict. It will just result in + and - .5 the secondary voltage.
disregard this thread. I just ripped apart a transformer and shorted the line common with the center tap, and it works fine.
WHOA! Be careful there. Make sure that the lead you shorted ALWAYS stays connected to the neutral if you do this in your project. If the input wires to the primary are reversed then the common ground/center tap on the output side will be 'hot'. Sounds like a potentially dangerous situation to me and quite likely not legal.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
