Can You Set Up 4 DC Motors in Parallel with a Variable Resistor and LED Strip?
The discussion revolves around the feasibility of setting up a circuit with four DC motors in parallel, controlled by push button switches and a variable resistor, alongside an LED strip. Participants explore the circuit's design, power requirements, and control methods, addressing both theoretical and practical aspects of the setup.
  • Experimental/applied
  • Mike questions the viability of his circuit design, asking if it can work as intended with the specified components.
  • Some participants, like Dave, point out issues in the circuit schematic, indicating that it lacks proper connections, which would prevent the motors and LED from functioning.
  • Mike seeks clarification on the purpose of a resistor in the LED circuit, suggesting it may be to limit current.
  • Baluncore explains the role of the resistor in controlling current through the LED, emphasizing the non-linear relationship between current and voltage for diodes.
  • Dave advises against using a variable resistor for motor speed control, suggesting that it limits current and power, and recommends researching PWM and H-Bridge motor driving techniques instead.
  • Concerns are raised about the power supply, with participants noting that a 12V 2A adapter would not suffice for multiple motors, as each motor could draw significant current, especially at stall.
  • Mike clarifies that he intends to run only one motor at a time for a project involving circulating water solutions, indicating that he may not need high current.
  • Another participant warns that the switches Mike plans to use may not handle the required current and suggests using a transistor for better control.
Participants express differing views on the circuit design and component choices. While some agree on the need for better current management and control methods, there is no consensus on the best approach to take or the specific components to use.
Participants highlight limitations in Mike's understanding of circuit design and Ohm's law, indicating that further research and learning are necessary for effective implementation. The discussion also reflects uncertainty regarding the power requirements and the suitability of the components chosen.
This discussion may be useful for hobbyists and students interested in circuit design, motor control, and the practical application of electrical engineering principles.
Dammert89
Good day. I was wondering if anyone could help me with the following problem. As you can see in the diagram below, I want to set up a circuit with 4 DC Motors in parallel, each with a push button switch. And a variable resistor to control the speed manually. I would like a LED strip to be connected as well as shown. The LED should always be on and the motors would only run one at a time as long as the switch is pressed. I need to know the following:
If this circuit is do-able?
What my power source should be? (Preferably a wall plug).
The LED won't pull that much current that the motors don't work will they?
Here is a list of the Items I am using. The motors I already have but the rest must still be ordered.
M: Motors: 4x RS-360SH
R1: Variable resistor: Either This one or this one.
S1-S4: Switch: Tactile Switch B1735
L1: LED: LED STRIP WHITE IP20
And my schematic
http://imageshack.com/a/img661/4373/7nFhRB.jpg
Thanks in advance!
Regards
Mike
Your circuit will not work at all. There is no voltage applied to any component.
Then what is the problem?
Greetings MIke
one side of the battery isn't connected to anything
both sides of the motors are connected to the same side of the resistor, once side directly, the other via the switch
therefore the motors won't work and the LED won't light either as only one side of it is connected to the battery
Am just a little busy at the moment ... I will try and get a chance later to redraw the circuit for you :)
cheers
Dave
Thanks davenn and Baluncore. Not to good with the schematics... I see there is a resistor in with the LED's? Why would that be? Each motors operating range is 3-12V and at maximum efficiency uses 1.76A. So I could use a 12V 2A adapter for this? And is that the reason for the resistor in with the LED(To bring down the current)?
It appears you have a very limited understanding of ohms law and circuits in general. That's ok, just take the time to learn it. Any diode, LED or otherwise, will only ever drop a fixed voltage across it before it destroys itself. This means that an LED that is conducting .02 amps for instance will drop about 2 volts. The same LED that is conducting .03 amps will also drop about 2 volts. The current and voltage do not have a linear relationship as a resistor does. That is the reason for the resistor. It limits the current. A 12 volt supply running an LED in the above schematic will have the resistor dropping around 10 volts assuming the LED has 2 volts across it. Do you know enough about ohms law to compute the required resistor size based on the spec of the LED?
Thanks Baluncore
I got tied up with work till last nite, didn't get finished till 1030pm
was going to do the diag this morning but you have filled in the gap :)
and one other thing ... to the OP
controlling motors with a variable resistor isn't a good way to go ... Yes you slow it down
by dropping the voltage, but you also remove much of its current supply which means it
cannot develop the same power at the slower speed
You may want to read up on PWM and H-Bridge driving of motors
cheers
Dave
No. If each motor draws 1.76A then a 2A supply can only supply one motor (two motors will draw 1.76*2A and so on). Also, the max current draw will likely be greater than the draw at max efficiency, the draw at stall could be double that. The actual current draw will depend on the load and the motor curve. If you draw a nice diagram of your intended plan we can offer some design input. Smaller motors may meet spec.
Max efficiency and 1.76 amp point on operating curve is per the datasheet at very low load.
The motor can pull over 8 amps at stall.
http://www.mabuchi-motor.co.jp/cgi-bin/catalog/e_catalog.cgi?CAT_ID=rs_360sh
What do you intend to spin with the motor?
Thanks for all the posts. Did a bit of research on the Ohm's law. Starting to understand it now. Probably should have done my research before I posted. Sorry guys. My plan is to have only 1 motor running at any time. never more than 1. It is a project that will just circulate various solutions of water. The motor comes with a centrifugal attachment. So I don't think I would need as much current. The water just needs to move as the button is pressed. Don't need a strong motor. Those are the smallest motors available that I can find in RSA. I came across a similar project using an Raspberry Pi and motor controller. That would ultimately be the best option I think? I reckon I will go with that tutorial and do it from there. Thanks again
Those switches will not be able to handle the amount of current required.
Look into using a mosfet or bjt and using the switch to turn on the collector or base of the transistor.
You will also want to add a flyback diode to protect the transistor.
I also highly recommend you follow the advice given before and put some thought into your motor controler
  • · Replies 20 ·
11K
