Can You Shape a Magnetic Field?
8 replies · 10K views
TrustyDelux
Hi all,
I have been playing around with some neodymium magnets recently and have found that although they are indeed very strong the 'range' of the magnetic field is not very large.
So I was wondering if there is a way to shape the magnetic field so that the magnets would attract/repel each other from a greater distace.
Hope I've made myself clear! :)
Thanks.
Not in any useful sense.
You can use soft iron to 'conduct' the magnetism much like a wire conducts electricity, but there's no way to get a 'focussed' magnetic beam such as I imagine you are thinking of.
Not really trying a 'beam' more like a 'stretched' field. I read somewhere that you can use sheets of aluminium or copper to do this.
Assuming that you understand that a magnetic field is not emissive(in the sense of a monopole) a magnetic field must have a return path to exist(as we currently understand; could change)
Because of this, options to "stretch" the field is limited, and requires additional components.
Even with additional components, the "stretch" is severely limited.
Aluminum or copper will only work for alternating magnetic field.
If you have a permanent magnet, the only thing that will achieve this sort of effect is a superconductor. A superconductor does not allow magnetic fields to pass through it (well, Type I doesn't, with Type II it's a little more complicated, but anyways...). So if you have a superconductor tube, and you put a magnet at one end of it, near the other end, it will be as if the magnet is right there.
Does connecting two permanent magnets with a soft iron rod extend the field as if it were a single magnet as long as the overall length?
Would the rod being a different diameter make a difference? (assuming identical size magnets)
If you represent the magnet as a pair of magnetic monopoles (yes, they aren't real, but it works as a mathematical trick) then yes, something like that can be done to separate the monopoles further without altering their strengths.
So is the best way to achieve a larger 'range' to shell out and buy bigger magnets? Or does this only increase the attraction/repulsion force?
The range is infinite and magnetic fields are divergence free.
If you want to pick up an iron ball from farther away, tape your magnet to a stick and then use that as an extension.
If you want to "collect" field lines inside a solenoid for example, use an iron core.
