Can't understand a proof in Rudin
  • Thread starter Thread starter kostas230
    Proof
kostas230
I can't understand a proof in the Theorem 2.27, part (a).
If X is a metric space, E a subspace of X, and E' the set of all limit points of E, we denote by \bar{E} the set: \bar{E}=E \cup E'
We need to prove that \bar{E} is a closed set. Rudin's proof is this:
If x\in X and x \notin \bar{E} then p is neither a point of E nor a limit point. Hence, p has a neighborhood which does not intersect E. Therefore, the complement of \bar{E} is closed.
My question is this: How do we prove that there exists a neighborhood that does not contain any limit points of E?
If every open ball at x contains a limit point of E, x would be a limit point of those limit points. Can you prove that it is contradictory for an open ball at x to be disjoint from E?
Edit: I changed "neighborhood" to "open ball", I think neighborhood is wrong although Rudin may define it differently.
I found a more straightforward proof. Suppose p is a limit point of E'. Then, for every neighborhood N_r (p) there exists a limit point q of E. There exists a real number h>0 with d(p,q)=r-h. Consider the neighborhood N_h (q)
d(s,p) \leqslant d(p,q)+d(q,s) < r
Hence, s\in N_r (p). Therefore, p is a limit point of E.
Did I get it right? xD
(BTW, I should mention that I'm a physics undergrad; no training in rigorous math except a linear algebra self study with Axler. So, I'm a little slow in this. xD)
That works. It is more technical than what I was alluding to above but it's fine.
You should probably mention that s is a point in E.
Likes 1 person
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
