Can't understand what's thermal equilibrium
Thermal equilibrium is defined as a state where temperatures are unchanging over time and uniform across space, and it is foundational to the concept of temperature, which is established through the zeroth law of thermodynamics. In thermal equilibrium, two systems in contact can exchange energy without any net energy transfer, meaning their temperatures must be equal. This state is characterized by an increase in entropy, as the total number of accessible states rises while energy exchange occurs. The definition of thermal equilibrium relies on the assumption that systems contain a large number of particles, leading to a unique temperature for each equilibrium state. Understanding these concepts is crucial for grasping the fundamentals of thermodynamics.
Tosh5457
In wikipedia it says: "Thermal equilibrium is a theoretical physical concept, used especially in theoretical texts, that means that all temperatures of interest are unchanging in time and uniform in space."
But isn't temperature defined because of the thermal equilibrium concept? It's defined because of the zeroth law, and the zeroth law uses thermal equilibrium concept.
Science news on Phys.org
Yes, first we define thermal equilibrium, then we define temperature.
Because temperature is relative?
If you have two systems which can exchange energy, but neither can do work on the other, thermal equilibrium is the state in which no net energy transfer takes place. It turns out one quantity has to be equal in both systems for this to occur, and we call this quantity the temperature.
Given two systems in "thermal contact" (aka, two systems that can exchange energy) and constraints on the combined system (for example, a constant total energy = U) we know that the entropy, aka the number of states, must always increase ignoring slight fluctuations.
The condition that an exchange of energy between the two systems has no effect on the total entropy is DEFINED to be thermal equilibrium. Temperature is then DEFINED by this thermal equilibrium condition.
The uniqueness of thermal equilibrium (aka, a single peak in the combined multiplicity functions) and therefore temperature is an assumption based on the properties of systems with very large numbers of particles.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
