Capacitive soil moisture sensor using TLC555
14 replies · 8K views
akaliuseheal
Hello everybody,
I have made soil moisture sensor and it kinda works. It is a capacative sensor not resistive sensor based upon TLC555 which has a role to create square wave. Square wave is brought to a homemade capacitor. Capacitance changes with change of moisture. Output is measured voltage on impedance (I have included the schematics).
Since it is capacative sensor, it should work when it is not directly exposed to water (in a plastic bag for expample) but it does not. Voltage remains constant when I submerge it in water while it is in a plastic bag but works when submerged without the bag. Homemade capacitor is made of copper plate like in the video. This should work, right? Have I made a mistake soldering it together?
TLC555: http://pdf1.alldatasheet.com/datasheet-pdf/view/28905/TI/TLC555.html
Youtube link: (06:52 for capacative type sensor)
Edit: Voltage is 5V
Why aren't the sensor GND and the IC GND connected?
They are, every ground including that "GND" is connected.
anorlunda said:
Do you have any idea what the capacitance is dry? and moist?
Vaule of C when submerged and when it is in the air? If that is what you asked, what I measured is 120pF when in air and 4.5nF when fully submerged. I measured it with cheep multimeter and wires used for connecting were around 70pF. Voltage measured when in air is 4.66V (when touching it with hand, voltage drops to around 3V and drops again when the slightest amount of water gets on it) , when fully submerged it gets down to 90mV and starts rising slowly.
220pF in schematics is changed to 330pF.
Vcc is 5V
Try it with no (or very little) air in the bag. The closer the water is to the sensor the more responsive the circuit will be.
Do you get the same results with and without bag when using distilled water?
Also what is the measured capacitance of the sensor when in the bag, both when in air and submersed in water?
It had no air, I used a tape like one in image provided
I see no reason to test it with distilled water since it won't be used with distilled water and I do not have it.
Capacitance does change even when it is covered with tape or a bag. I don't have the numbers right now but that part of a sensor works just fine.
However, measured voltage does not, only when copper plate is directly exposed to water.
That's why the distilled water test. I suspect the reason it works only when in contact with the water is because conductivity is being sensed, masking any capacitance change. Clean distilled water has very low conductivity and would confirm/eliminate that possibility. If you are in the USA, distilled water is available for about USD $1 in larger grocery stores. Or you can boil some water on the stove and collect the steam as condensate.
Cheers,
Tom
Sorry for the late reply, I haven't had a chance to test it since I was busy. If that is true, does that mean that I will need a larger capacitance. I have not used the same size copper plate as shown in the video, it is more like the size of that arduino sensor.
You need a circuit where small changes in capacitance cause a measurable effect, and changes in resistance can be separated or ignored. Perhaps an oscillator bridge which changes frequency when capacitance changes. To design it you need estimates of the minimum and maximum capacitance.
Caveat: I am not a circuit designer. I know the principles, but other PF members can help with more specifics.
Measure the resistance of the sensor itself both in and out of water. Use your Ohmmeter on its highest range.
You need an insulating coating on all sensor/conductive surfaces that get damp/wet, the thinner the coating the better. Just painting it with some oil based paint may last long enough for testing. Or glue a layer of a thin plastic bag over the sensor. Spread on a thin layer of glue, then rub the plastic to squeeze out excess glue and air bubbles.
For longer term use, a coat of epoxy would be better.
Cheers,
Tom
you forgot the diode
In the circuit shown in post #1 there are two things I cannot quite understand:
  • You have drawn GND and Output as attached to a connector. What about VDD?
  • The Output is connected to GND through a capacitor and a resistance, which means that
    • Essentially no pulses will appear on Output
    • A highly capacitive load is connected to OUT. Is that allowed according to the specs?
You have a 1uf capacitor in parallel with your probe. the dry capacitance is therefore 1.000120uF and the wet capacitance is 1.0045uF. This is less than half a percent difference.
Also the probe is connected to the output.
I found the circuit akaliuseheal is trying to build. The diode and a 1nF capacitor makes much more sense.
BoB
